I did correct the schematic and layout, or is there some other error in it still? Also, I know it's not the same. I just wanted something a little dynamic to look at.
Since 0.2 ppm/C 80k's are available after all (at a price), I don't think there's much purpose left in trying to sort 10ppm resistors. I'll certainly use cheaper resistors for the first trials, though.
My focus will be back on the NU180 board now, since I have to redo it from scratch yet again (resistor footprints have to be made larger, which messes everything up).
I noted the noise tests by wanghar, which are a little startling. I wonder which parameters in the spec sheets, if any, reflect noise? I suppose bandwidth differences are a possibility. The TMUX version he tried quotes 200 MHz under certain conditions. The ADG version quotes 160 MHz, -3dB. The 74LV4053 doesn't seem to list that, but its on-resistance is far higher, so one presumes that the bandwidth is lower. It's not clear to me what the bandwidth needs to be, but when using multi-kilo-Ohm resistors, it can't be too high. What other parameters might indicate noisy vs. quiet switches?
The 74LV4053 isn't as appropriate for this project since the control scheme is different, the on-resistance is higher than any of U180's switches, and 4 channels would be better if possible. I'm still open to suggestions, including a little higher on-resistance ones if there are other benefits. I had a quick look at the TS3A5018 10-Ω chip, for example. It has higher on-resistance but other parameters are a little better.
