Author Topic: Power supply for voltage references  (Read 86951 times)
Offline iMo
  • Country: li
Re: Power supply for voltage references
« Reply #200 on: August 08, 2025, 04:48:24 pm »
The main function of R3(R5 inrevised sch ) is to offload a portion of the thermal load from the L7805. Assuming the FPGA/MCU current consumption is 30mA, the voltage drop across the 100-ohm resistor will be 3V. This reduces the voltage drop across the L7805, preventing heat dissipation from being concentrated solely on the L7805. I've changed the resistor package to 1206.
I would put there a 3.2V zener as the serial voltage dropper (HP does it in its high end meters, for example). But wired after that CLC low pass (like the R7 is wired)..
« Last Edit: August 09, 2025, 05:54:07 am by iMo »
Offline aronake
« Reply #201 on: October 30, 2025, 12:00:33 pm »
One idea:
On the AC side, start with one DP-241-5-120 transformer to go from 220V to 120V, then one DP-241-5-12 (with primary in parallel) to go from 120V to 12.6V AC, then a linear regulator to 12V or what voltage may be wanted.
Idea then that there are two transformers in series that each help to reduce lekage.
The DP-241-5-12 transformer is the one Marco Reps tested for leakage here:
https://youtu.be/9JinSfCKuNQ?si=DwPtIN2V676FicvO&t=565
https://www.belfuse.com/media/datasheets/products/transformers/ds-st-241-series.pdf
