Author Topic: Power supply for voltage references  (Read 87370 times)
Offline exe
  • self-educated hobbyist
Re: Power supply for voltage references
« Reply #175 on: April 01, 2025, 06:06:02 pm »
Could it be because most of the noise comes from dead time? We'll see, I'm building a small proto board to play with. I'll try different parts with different slew rate.
Question: does transformer's V-t product depends on the load? I mean, can I violate it if there is always a load? My logic is that some energy will go to the output, so less chances to saturate the core.
Online Kleinstein
« Reply #176 on: April 01, 2025, 06:23:24 pm »
The required V-t product does not change much with loading. Essentially all of the output current will come from the input side as additional input side current. It is only the small voltage drop at the swich and winding resistance that reduces the effective voltage.
One can reduce the input side voltage if absolutely needed.
The following users thanked this post: exe
Offline DeltaSigmaD
« Reply #177 on: April 01, 2025, 11:09:33 pm »
Power supply with low leakage with LT1683
I'm missing the LT1683 in the mentioned list of push-pull controllers. I developped a power supply with this LT1683 since it has a slew-rate control feature to minimise noise. My application is a supply for external test circuits, e.g. a controlled voltage reference, which are working inside a current acquisition system operating in the pA to uA range with fA resolution. The entity "leakage current" (LC) must be defined: this is not the differential noise generated by the power supply (which may be actually very low), but the current flowing through the ground connector (not protection ground) of the power supply when it is connected with the protection ground of the power line system. Many manufacturers do not specify this LC. A good value for LC is less than 1 uArms (broadband), but even this is much too high when you want to measure fA (current between Gnd of supply to Gnd of acquisition system).
I tried a design with the double ferrite core topology (coupled by a short-circuit winding) as dc/dc transformer to reduce the coupling capacitance and hence the LC. It was hard to find a useful loop compensation. The slew-rate control of the LT1683 is working insufficiently with this transformer type. Therefore, the switching noise spectrum is unexpectedly high which can't be accepted. I had to reject this design.
A dual core transformer has a considerable stray inductance, so that many push-pull controller ICs will have problems with this topology. In general, it is difficult to suppress the noise of push-pull controller ICs : the duty cycle and the switching frequency are not stable enough to attenuate the noise by digital filtering performed by the data acquisition. Any nonlinearities mix varying switching noise down to the base band. Spread spectrum is useless for these applications.
Therefore, I'm just developping a power supply on base of a microcontroller. The focus is directed on low leakage by a dual-core transformer and constant frequency by a quartz. The duty cycle can be fixed to obtain a stationary noise spectrum, taking a worse power efficiency into account. I will report here the results, hopefully in a few weeks.
The following users thanked this post: Mickle T., Andreas, MiDi, ch_scr, miro123
Online trobbins
« Reply #178 on: April 02, 2025, 01:34:16 am »
Another option to suppress coupling capacitance between input source and destination supply is to use multiple small commercial dc/dc, such as from vintage Newport, but now C&D etc.  For example a 5V to 5V dc/dc NMA0505S has 100mA output capability with 28pF coupling.  Two to three of those in series, along with an isolated plug-pack, should suppress coupling to <10pF in a convenient, relatively cheap, off-the-shelf, space-saving manner.
That style of isolation has many model variations to allow different input and output voltage rails, and power rating, to suit an application, and some have lower coupling cap.  The final dc/dc in the chain may benefit from some L-C filtering to suppress residual hf ripple, and a final linear regulator IC.  I haven't personally tried this to confirm no anomalous behavior from interaction between converters.
Online Kleinstein
« Reply #179 on: April 02, 2025, 06:57:25 am »
The LT1683 is not made to directly drive a transformer, but for external MOSFET switches and thus for higher power. So it would be an odd choice for a low power solution. The extra area and traces alone can be an issue with radiated EMI.
The weak point with the push pull converters is the fast switching and related EMI issues at rather high frequencies (e.g. ~ 100 MHz in the SN6505 snubber appl. note). This part can be hard to predict and depend on resonances in the layout / wireing.
For the capacitive coupling it is not only the capacitance that matter, but also the effective voltage at the transformer. Here symmetry can help and shield in the transformer can help with symmetry. An easy point to keep the voltage low is to use low voltages at the transformer. So more a 5 V to 5 V transformer and if needed a charge pump for higher output voltages. The overall capacitance to ground also has the case and cable capacitance for the outputs. The transformer is only a part of it.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #180 on: April 03, 2025, 06:44:16 am »
Yesterday i looked at a Wien oscillator with a TL082 that i made some years ago. I removed the jfet gain control, so it produces a clipped sine wave of about +/- 12 V from a +/- 15 V supply. Second opamp is used as inverter. Adjusted frequency to 25 KHz.
At the time i wired it with four larger bipolar transistors as output buffers, but i think the opamp might handle the supply of a reference all by itself. At the time i hand made a small toroid 1:1 transformer with 2.2 mH coil inductance, coupling of 2.5 pF and a shield. It's impedance is low for use without the buffers.
Then i found two pieces of VAC 4097X011 transformer in a drawer. Those are 1:1:4 transformers, roughly the size as the WE part mentioned above by Kleinstein, except the "4" coil has 200 mH inductance and 2 Ohm resistance. That appears to be a good solution. Coupling capacitance is 25 pF. A RRO opamp with good drive capability can improve the circuit.
Looking to buy that transformer, i couldn't find an offer. Yet i found another interesting part: VAC 4099X011. That is a 1:1:1 transformer with 0.95 mH per coil and a low 2.5 pF coupling spec.
Another useful part may be the black Schaffner 100 mH common mode choke. I measured a coupling of 21 pF. Two of those can be used: as transformer and as common mode filter.
Regards, Dieter
« Last Edit: April 03, 2025, 06:53:18 am by dietert1 »
The following users thanked this post: exe, ch_scr
Online Kleinstein
« Reply #181 on: April 03, 2025, 07:14:06 am »
The idea with a clipped sine looks OK. As a driver I would consider a small audio amplifier like LM4871 (5 V brigde for 3 W). Full bridge drive would ideally keep the average votlage at the coil constant, which could help with the effective voltage for coupling.
For the waveform one anyway has to compromise between the voltage waveform and current waveform. A sine voltage tends to cause pulsed current with a simple rectifier.
The following users thanked this post: exe, dietert1
Offline David Hess
  • DavidH
« Reply #182 on: April 03, 2025, 10:42:28 am »
Also look for gate drive transformers.  They have about the right characteristics.
Offline exe
« Reply #183 on: April 23, 2025, 05:36:17 pm »
So I built the push-pull circuit. It supposed to boost voltage from 3.7 to some 21V. I think I made a mistake somewhere, as output voltage (unloaded) is 26V at only 3.1V input. Trying to increase the voltage I got current quickly increasing. I guess either diodes give up, or I overload the transformer's VT. I might miscalculated something. Circuit main components:
- trafo: wurth 750317072 https://www.we-online.com/components/products/datasheet/750317072.pdf
- driver: NXF6505B https://assets.nexperia.com/documents/data-sheet/NXF6505_Q100.pdf
I think it's a moderate success, given the fact that trafo has quite some long leads inside the enclosure, and there is no snubber yet.
But I'm struggling to measure the noise, because I got 6-7mV p-p noise (full scope BW, >100MHz), regardless of leads connected or not (measured at the output, after LC-filter).
If I use 1X probe, and limit BW to 1MHz, I got 220-300uV p-p noise, according to my scope, regardless the probe is connected or not. Go figure  :-//
Question: is it normal in trafo I got 4X the input voltage? If you look at the input, you'll see 12V (plus ringing) p-p, but supply is only 3.1. I kinda expected it to be 2X  |O
Online Kleinstein
« Reply #184 on: April 23, 2025, 06:02:28 pm »
If one used the full winding at the secondary 4 x the input voltage is normal for the peak to peak value. Half the winding at the primary side see both a positive and negative voltage. So 2 x the input voltage as peak to peak for the primary (half winding) and thus 4 x for the full secondary.
The unloaded output voltage can be higher from the ringing part on top.
Offline exe
« Reply #185 on: April 23, 2025, 08:04:41 pm »
I put 220 ohm resistor on output, got voltage dropped to ~16V (72mA output current). Input current is 0.5A.
The output noise because 36mv p-p (full bandwidth)  :palm: . I didn't investigate further, but spikes are ~1us apart, roughly matching switching frequency (~450kHz). Also the drop is much more severe than I expected, I lost 10V on the output.
Offline EC8010
« Reply #186 on: April 23, 2025, 08:37:53 pm »
I've just looked at the PCB photograph in post #183. This is to be a clean supply for a voltage reference, right? It won't be with all that flux left on the PCB. Trust me; deflux properly and you will see circuits work better. "Properly" means holding the board vertical and scrubbing with defluxer from top to bottom to release contamination, shaking as much liquid off as possible then immediately rinsing and scrubbing from top to bottom with isopropyl alcohol to dilute and lose the contamination, and immediately drying with a pre-warmed hair dryer. Then do the other side. Then the first side again. Then the second side again. Not only does it make your soldering look much nicer, but it all works better, and with low noise or low current stuff, that's important.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #187 on: April 24, 2025, 06:49:43 am »
I see only one buffer cap close to the driver IC while the original schematic in post #175 had two of them, maybe 100 nF and 10 uF. Also it appears like the two primary side snubbers vanished.
Did the driver IC change from ..A (160 KHz) to ..B (420 KHz) due to transformer saturation?
Regards, Dieter
Edit: I think the 16 V is roughly what one expects, as the turns ratio of that WE 75037072 is 6.17. So if you start with 3.1 V you end up with 19 V minus driver saturation and diode voltage loss. Note that the primary inductance is 200 uH but in your circuit that divides by 4 as you drive each half separately.
« Last Edit: April 24, 2025, 07:19:38 am by dietert1 »
Online Kleinstein
« Reply #188 on: April 24, 2025, 06:58:49 am »
The higher frequency of the B version is kind of needed to avoid saturation with that transformer. The scope confirms the higher frequency.
An asymetric load on the output side (one side rectification) can also drive the core slightly into saturation and this way increase (maybe double) the current needed. In the extreme case diode self heating may shift a rectifier to asymetric operation.
Offline branadicTopic starter
  • www.qoool-sensing.org
« Reply #189 on: August 03, 2025, 05:45:56 pm »
Not sure anyone noticed Shahriar's video https://youtu.be/y3f1qwPo_TY and the Harmony Pi filter component that was presented by TransSiP? They were kind enough to send me their EVB and some samples free of charge. I will test them in an application, in which I need to create low noise power rails from USB using a DC-DC-converter. While the current version is rated for 6 V, a higher voltage variant is already in progress, I was told.
-branadic-
Measuring is like guessing, but more advanced.
The following users thanked this post: miro123
Online Doctorandus_P
« Reply #190 on: August 03, 2025, 11:11:34 pm »
I wonder why the Austin transformer has not been mentioned yet in this thread.
They are designed for both high voltage isolation and low capacitive coupling, and they are used to couple mains voltage for lights and such into live broadcast masts.
https://en.wikipedia.org/wiki/Austin_transformer
Offline exe
« Reply #191 on: August 07, 2025, 08:17:01 pm »
Are they suitable for low-power equipment? Most pics from the internet show big installations.
I see a problem assembling a small device. If two ring cores are used, one has to be split and the glued back together? The split kinda adds an airgap, which is, I think, not needed here.
Offline David Hess
  • DavidH
« Reply #192 on: August 07, 2025, 09:12:40 pm »
Oh, so there is a name for those.  I have an old (1960s?) plug-in high isolation power supply which uses transformer steel laminations to make that 90 degree double core arrangement.  I think it was rated at 18 volts and 30 milliamps.
Online Kleinstein
« Reply #193 on: August 07, 2025, 09:26:05 pm »
I don't think there are 2 cores. It is one ring core with the primary wound directly on the core. Different from more normal toroidial transformers the  ration of inner to outer diameter is relatively large - so quite some space for windings.
The special point is the secondary that is  with maximum distance and air for insulation.
The way it is build the secondary windings are quite a bit longer than for a more normal classical windings directly on top. This causes increased resitance loss and with a small size this gets more of an issue. So mains frequency and small size would be rather poor efficiency (e.g. 40 % instead of 60% for a more normal shape). Larger size as on the photos the drop in efficiency would be not as bad (e.g. maybe 90 % instead of 95%). With higher frequency the winding resistance is less of an issue.
A downside of the Austin transformer is that there is a relatively strong stray field.
Offline wanghar
  • Country: cn
« Reply #194 on: August 08, 2025, 08:15:45 am »
Trying to design a Type-C powered supply module for my newly designed FPGA-based MS-ADC.
Need ±15V for the main analog stuff (op-amps, ADR1399 or LTZ1000 ref).
Need +5V mainly for the flip-flops and analog switches.
The +3.3V for the CPLD/FPGA will be stepped down from the +5V on the main board.
Component Choices:
Skipped the classic L7815/L7915 – not enough voltage headroom (dropout) for them here.
Went with ADP7118/ADP7182 instead. Overall performance should be better... though admittedly pricier.
First time using the SN6505B! Just sketched the circuit so far – haven't actually tested it yet.
P.S. --obviously LCEDA uses  a wrong 3D model for L7805, so just ignore this fault.
Offline miro123
« Reply #195 on: August 08, 2025, 08:38:31 am »
-branadic-
I really wonder from the results.
I have one question. Does the filter attenuate the common mode noise?  When I look at schematics they use a common ground symbol. On another circuit they shows  connection of two grounds together somewhere.
« Last Edit: August 08, 2025, 08:50:54 am by miro123 »
Offline iMo
  • Country: li
« Reply #196 on: August 08, 2025, 09:16:06 am »
Trying to design a Type-C powered supply module for my newly designed FPGA-based MS-ADC..
Nice..
I would put a shielding over the parts - see below.
Not sure where to ground it, however..
PS: I would also add small caps, like 1-10nF for example, in parallel with those 4u7 tantalums (and to that 1/10uF around the L5 too) in all those CLC filters there..
Also I saw somewhere doubling a single CLC filter helps a lot too..
Why the R3 is placed there as-is?
« Last Edit: August 08, 2025, 09:36:56 am by iMo »
Online Kleinstein
« Reply #197 on: August 08, 2025, 09:42:20 am »
The HarmonyPI filters seems to be for the rather high frequency part. There a good CM filter can be relatively easy and work well.
For an isolated precision supply the difficulty is not so much in the really high frequencies > 10 MHz, but more with lower ones (like 100 kHz or what ever the switching frequency of the transformer). Here the impedance at the output side is not necessary that low, as it is mainly the capacitance to ground that sometimes also is wanted to be not that large. So I am afraid no magicly improved CM filter here.
@wanghar:
The CM filter looks rather small, not sure if this would help very much at the frequency of the SN6505 and with a not so low impedance to ground.
The SN6505 ideally wants some snubbers for the 100 MHz range - Ti has a AN on this. Ideally I would include a bit more capacitance on the input side of the DCDC converter - with USB there is however some limit (some 10 µF AFAIK) on how much is allowed there.
The diodes at the rectifier would see a peak voltage of a bit over 2 x the DC output. So more like 40 V or even 50 V diodes needed.
The filter design is somewhat sensitive to the layout, especially with the ground. It may help to separate the first filter stage with most of the AC currents from the rest with only a single ground link from there to avoid ground loops all the way to the output.
I don't think 1 nF caps in parallel to the tantalums would make much difference. Some 100 nF or 1 µF MLCC could still make sense. At least have the option for a few more capacitors if really needed.
P.S. the LDOs for the +-15 V looks rather small size. They may still need a bit more cooling, especially for the start up of a heated reference.
« Last Edit: August 08, 2025, 09:45:36 am by Kleinstein »
Offline wanghar
  • Country: cn
« Reply #198 on: August 08, 2025, 03:30:31 pm »
@Kleinstein
I took a look at TI's application notes(slla566a, slla436 and sllu223) then made some modification on the schmetics:
1) add more capacitance on the input side of the converter and follow the layout guide TI sugggested in ANs. Also add a few pcs of 104 mlcc on the output side of converter.
2) Reserve snubbers place holders on board, the values of R and C need to be determined later.
3) The currently placed CM filter has a impedance of 1000Ω @100MHz, almost be no effect for the SN6505B when it works at 420KHz.  considering remove or short.
4) You are right the diode need to be re-spected with a higher voltage. Changed to MBR0540 or 5819.
Offline wanghar
  • Country: cn
« Reply #199 on: August 08, 2025, 03:52:32 pm »
@iMO
I do not think that is a good choice to use a shield covering both input and output portion of the converter(transformer). Taking reference from TI EVM board I also use 2 seperated copper pour on the PCB (before and after transformer) to serve certain shielding effect.
The main function of R3(R5 inrevised sch ) is to offload a portion of the thermal load from the L7805. Assuming the FPGA/MCU current consumption is 30mA, the voltage drop across the 100-ohm resistor will be 3V. This reduces the voltage drop across the L7805, preventing heat dissipation from being concentrated solely on the L7805. I've changed the resistor package to 1206.
« Last Edit: August 09, 2025, 02:28:49 am by wanghar »
