Author Topic: Who Has The Best Home-Made 10Vdc Reference?  (Read 13747 times)
Offline CalibrationGuyTopic starter
« on: May 20, 2024, 05:47:35 pm »
Hello everyone! As some of you know, I have a calibration lab and I enjoy testing voltage references and have dabbled with creating my own. However, after perusing the threads here, I see that my efforts have been eclipsed by some epic efforts by the likes of Dr. Frank, Andreas, Branadic, TiN, et al. I have several Fluke 732 references. One of my older units, a 732a has an extraordinary drift history. I measured it once with a Keysight 3458a that was right back from a metrology lab calibration from Keysight (compared with their Josephson array) 20 months ago, and once again recently with the same meter back from another metrology grade calibration. The result: 0.3ppm difference! Yes, the temp/humidity was the same for both measurements, same cable connecting the units, RF field measured, ACAL ALL, 200NPLC, etc,, etc,, etc. An incredible result. Of course, if we apply all the uncertainties, a cynic can say that this is hardly definitive proof. Well, I concede that point, but now I have 2 more 732a units, a 732b, and 732c which will give me really good data points in the coming years.
So, sorry for the long winded intro, but my question is this: Who has the best reference here? I mean one that they've built. Also, you have to back up your claims by comparisons to a known voltage reference such as the 732. I have 4 3458a meters sitting on my bench right now and can see them drift over the course of 24 hours by 0.3 to 1.6ppm max difference between them.
Looking forward to your responses!
TomG.
My apologies for forgetting Kleinstein!
« Last Edit: May 25, 2024, 12:36:39 am by CalibrationGuy »
Offline Grandchuck
Re: Who Has The Best Home-Made 10Vdc Reference?
« Reply #1 on: May 20, 2024, 06:43:12 pm »
Here is a shot of one of my reference units.  3 copies of Dr. Frank's design.  My 3458A readings wander about +/- 1.5 ppm.  I have checked calibration using the standard designed and built by TiN (USA Cal Club).  I don't think I can achieve anything more as a voltnut without going into more expense and time than I am willing to invest.
« Reply #2 on: May 20, 2024, 08:30:27 pm »
That's a very nice looking project. If you have time, it would be nice to see the front panel with one of the outputs hooked up to your reference meter.
TomG.
Offline Grandchuck
« Reply #3 on: May 20, 2024, 08:48:01 pm »
Sure TomG.  Thanks for the kind words!
I added a 7 hour graph.
« Last Edit: June 05, 2024, 06:48:21 pm by Grandchuck »
« Reply #4 on: May 20, 2024, 09:14:07 pm »
Thank you for that picture. I assume the panel meter is monitoring your power supply voltage. We are sending one of our Fluke voltage references to Keysight soon. It's part of our effort to get under the half part per million uncertainty certification @10Vdc. Once that happens we can characterize your home project if you are curious as to how close it is to 10.00000Vdc. You pay the shipping. The test is free, but I can't give you an official calibration report. Otherwise, my corporate clients would be really not happy.
TomG.
Offline DimitriP
« Reply #5 on: May 20, 2024, 09:25:20 pm »
No one will ever speak of it. Ever. To anyone. At all.
The following users thanked this post: CalibrationGuy
« Reply #6 on: May 20, 2024, 09:35:03 pm »
I think you may be right. Unfortunately, some of my clients are on here, and there's nothing to stop anyone from posting images on this board. But yes, the chances are only slightly better than winning the lottery. And yes, that was pretty funny.
TomG.
Offline Grandchuck
« Reply #7 on: May 21, 2024, 11:18:01 am »
Yes, the panel meter is indicating the voltage before the 12 volt regulator.  It was once connected to one of the reference outputs but always displayed 10.000 ... how boring :P
Offline branadic
  • www.qoool-sensing.org
« Reply #8 on: May 21, 2024, 11:45:21 am »
From what I observed during my own experiments, these 5-digit panel meters create a lot of noise and interferrence, hency why I ditched them also in my low noise power supply and replaced them by analog panel meters. Just my 2 cent.
-branadic-
Measuring is like guessing, but more advanced.
The following users thanked this post: Mickle T.
Offline Grandchuck
« Reply #9 on: May 21, 2024, 11:48:59 am »
Yes, the switch is to turn the panel meter off and it is almost always off.
Online IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #10 on: May 21, 2024, 02:13:46 pm »
I was wondering about that. How about displaying the internal temperature of the enclosure?
Ian.
Website: www.ianjohnston.com
Offline Grandchuck
« Reply #11 on: May 21, 2024, 04:52:19 pm »
Hi Ian.  That was the setup a while back.  It worked but did not actually help my volt nutting.  My lab is almost always at a rather constant temperature (unless we have a power outage).
It turns out that occasionally one of the chopper amps latches up and this can be detected by monitoring the unregulated dc supply.  It happens rarely and only when connecting/disconnecting the output jacks.
BTW, my PDVS2mini is sill serving me very well.  I never adjusted/recalibrated it ... no need to!
The following users thanked this post: IanJ
« Reply #13 on: May 21, 2024, 11:49:53 pm »
That must be a revision b board. Mine had aluminum foil, so a few more ppm off.
TomG.
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #14 on: May 24, 2024, 09:19:37 pm »
You've made me to remeasure my home-made reference. I am not claiming it is best though it has kept its 10V output inside probably 10ppm for last 8 years or so (if measured at the same temperature as the tempco is not small, at 25C it is about -1ppm/C ). It is certainly different from the majority, I might yet to come back and do some more work on it now that I have the HIOKI DM7275 voltmeter which would make it easier to measure.
Cheers
Alex
« Reply #15 on: May 24, 2024, 10:29:01 pm »
Now you're making me read yet another voltage reference thread! This forum is quite addictive, I must say.
@Alex: The performance of your reference is impressive!
TomG.
    • A.N.T. Audio
« Reply #16 on: May 24, 2024, 11:00:47 pm »
TomG.
Thank you Tom, I suppose for a prototype assembly it is good. I've used a metal can JFET (available from stock at Mouser for about $3 each), and well aged Ultrohm WW resistors that seems to be very stable (as the 10V output depends both on the JFET reference output (around 7V) and the step up amplifier. I had some plans to improve this reference, perhaps now I will build another one with some updates, first of all the temperature control would be interesting, as the "zero" tempco point can be adjusted easily for a particular temperature.
Cheers
Alex
« Last Edit: May 24, 2024, 11:55:48 pm by Alex Nikitin »
« Reply #17 on: May 25, 2024, 03:35:14 am »
Ok, looks like I've been inspired to throw my hat in the ring. I have an advantage in that I have a calibration lab at my disposal for testing a few designs. In particular, I have a 732a that has drifted only a few microvolts in over 20 months. Perfect for long term drift testing.
Some thoughts:
I was interested in using the ADR1001 because 10V and 5V outputs are useful to me, but they're not available readily yet.
The ADR1399 looks promising, but I was looking for 3458a level performance. Maybe 4xADR1399 is a possibility.
The LTZ1000 is another option. Reference circuit with a 7V to 10V amp/buffer circuit. The buffer circuit may be heated and/or compensated with resistors of positive and negative tempcos.
Of course the ADR1000 as an alternative to the venerable and widely tested LTZ is also an option, but I hear that it takes many months to stop drifting, and there is no long term drift data yet.
All of these options have been discussed in great detail here.
Suggestions as to which option I should try first are welcome.
PS - Low drift is priority one with noise a close second.
TomG.
« Last Edit: May 25, 2024, 05:35:34 am by CalibrationGuy »
Offline jewelie
  • Everyone's gotta start somewhere
    • Personal website, of sorts, sometimes with a Pi-driven bird-feeder webcam (currently down but will be putting it up again in the near future with IR capability.)
« Reply #18 on: May 25, 2024, 06:09:19 am »
D105-10 (REF102) from Awesome14 (Kaysert - Tom Kayser) gets my vote :popcorn:
Christ on a bicycle!  What a rabbit hole that was!
Anxious newbie to EEVblog.  Resuming an interest in basic electronics after a close shave with a joint EE/Computing degree decades ago
Offline Overspeed
« Reply #19 on: May 25, 2024, 10:08:30 am »
from https://www.eevblog.com/forum/metrology/calibratory-d-105-dc-precision-voltage-reference-standard/msg600690/#msg600690
from https://www.eevblog.com/forum/metrology/calibratory-d-105-dc-precision-voltage-reference-standard/msg606722/#msg606722
from https://www.eevblog.com/forum/metrology/calibratory-d-105-dc-precision-voltage-reference-standard/msg602915/#msg602915
Hello
This '' thing'' is a nice demonstration on how to built something bad , metrology level can reached with DIY equipment but that request a bit of cost analysis and respect in design , except if you lost in the middle of no where or stuck during a weekend by bad weather ....
A descent quality PCB cost 2 Euro ...so why use a prototype board with ugly soldering
Regards
OS
Offline HighVoltage
« Reply #20 on: May 25, 2024, 10:12:42 am »
Hello
Regards
OS
You need to read the full thread to understand.  :-DD
It is the funniest thread on eevblog, but it is long, we had a good time.
The following users thanked this post: MiDi, Overspeed
« Reply #21 on: May 25, 2024, 03:16:52 pm »
Some thoughts:
TomG.
Let's not derail this thread. Any thoughts or comments on my questions?
Offline Doctorandus_P
« Reply #22 on: June 02, 2024, 10:19:11 am »
Marco Reps has build some amazing things. He has built:
https://github.com/marcoreps/ADRmu
And now he is working on a stepper motor driven switch box to do automated long term drift measurements between an array of those things, also featured on Hackaday:
https://hackaday.com/2024/05/27/reinventing-rotary-switches-with-stepper-motors/
« Reply #23 on: June 02, 2024, 06:21:05 pm »
Is that the "precious ppms" guy?
TomG.
Offline Roehrenonkel
« Reply #24 on: June 02, 2024, 07:30:26 pm »
Yes, and he has the "Safety-socks"!  :-)))
Anyone still using VXI-Bus?
