Author Topic: Cheapest VHDL learning platform  (Read 8897 times)
Offline filip_cro
  • Country: hr
« on: November 30, 2013, 06:53:23 pm »
I'm looking for breakout board with FPGA or CPLD. I'm want it to have programing via USB.
Also I want to have good datasheet and support by other users.
Offline Fsck
  • sleep deprived
Re: Cheapest VHDL learning platform
« Reply #1 on: November 30, 2013, 06:58:39 pm »
The DE0 Nano is probably the cheapest common board I can think of.
"This is a one line proof...if we start sufficiently far to the left."
Offline NANDBlog
  • Current job: ATEX certified product design
« Reply #2 on: November 30, 2013, 08:22:05 pm »
I believe that the digilent basys 2 offers more for only extra 10 bucks. Besides, it is xilinx.
Offline filip_cro
  • Country: hr
« Reply #3 on: November 30, 2013, 08:46:33 pm »
I still need something cheaper.
Offline Icarus
« Reply #4 on: November 30, 2013, 09:04:46 pm »
There are some boards in $12 to $50 range
http://dx.com/s/fpga
Offline filip_cro
  • Country: hr
« Reply #5 on: November 30, 2013, 09:32:01 pm »
"CPLD FPGA USB Blaster Rev.C" is fake one. Dose it work with Altera official software?
Offline zapta
« Reply #6 on: November 30, 2013, 09:39:43 pm »
You don't need a board to learn vhdl, a free simulator will do, check Xilinx free web pack.
Sent from my Galaxy Nexus using Tapatalk 2
Drain the swamp.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #7 on: November 30, 2013, 10:03:28 pm »
I guess you mean the Xilinx part to be a negative side.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline Kohanbash
    • Robots for Roboticists
« Reply #8 on: December 01, 2013, 12:41:57 am »
You just need to be careful since a lot of things in VHDL work in simulation but are not synthesizable.
Robots for Roboticists Blog - http://robotsforroboticists.com/
Offline nuhamind2
  • Country: id
« Reply #9 on: December 01, 2013, 02:00:59 am »
ftp://
I have one for 10$, the download function work.havent tested other function
Offline NANDBlog
« Reply #10 on: December 01, 2013, 09:32:54 am »
Xilinx is a good learning platform, kinda like AVRs nd PIC16s. For learning you dont need the best performance/price manufacturer or IC. You need a lot of examples and support. and xilinx has that.
Offline Stonent
« Reply #11 on: December 01, 2013, 09:58:12 am »
Dangerous Prototypes has 3 different cpld boards for $15
http://dangerousprototypes.com/2013/02/03/vhdl-tutorial-using-xilinx-cpld/
« Last Edit: December 01, 2013, 10:01:02 am by Stonent »
Offline crispus
I know I'm numskull, but I look around me and I feel better.
Offline marshallh
    • retroactive
« Reply #13 on: December 01, 2013, 07:53:32 pm »
Keep in mind the Cyclone II (EP2C series) are no longer supported by the newerst version of Quartus (you must use 13.0sp1)
Verilog tips
BGA soldering intro
Offline mrflibble
« Reply #14 on: December 02, 2013, 10:44:31 am »
Indeed. When trying to learn vhdl/verilog for synthesis, it helps to target an actual fpga and run it through the synthesizer. Which means installing the free tools from xilinx/altera/lattice/whatever, and doing a full P&R every now and then to see if everything is kosher.
Or alternatively, first learn it all in a synthesizer. And then later find out some of the construct you liked so much will not work for synthesis. Pick whatever learning method you like. :)
If you're still on the market for a board I suggest an fpga (not a cpld), because you'll have a bit more resources to play with during learning. And I would also suggest getting an fpga that is at least somewhat recent. As in why get a spartan-3 when spartan-6 boards are affordable as well and give you more capabilities. Same for Cyclone II vs Cyclone IV.
Anyways, the absolute cheapest way to check if it is at all your kind of thing or not is to install the free vendor tools and play around with that for synthesizable code.
Offline Fsck
  • sleep deprived
« Reply #15 on: December 02, 2013, 10:47:33 am »
though, technically if you want to be at the forefront of xilinx with vivado, you're forced to use 7-series or (technically, though not released yet) above which dramatically limits your choices.
Offline mrflibble
« Reply #16 on: December 02, 2013, 11:02:59 am »
Which is why for the xilinx flavor I suggested spartan-6, as opposed to anything from the 7-series. Those are still disproportionately expensive IMO. And for Altera I am not all that well informed, but a quick check suggested Cyclone IV to be the sweet spot (DE0-Nano for example). Cyclone V looks cool and all, but probably a bit too expensive as well. Although ... a Cyclone V GX Starter Kit doesn't look too bad at $179. And it even has an arduino header, I always wanted one of those! ;)
Offline filip_cro
  • Country: hr
« Reply #17 on: December 02, 2013, 03:03:23 pm »
I see that best thing for now will be using simulator to learn basics. How hard is to get DE-0 Nano (http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=139&No=593)
for academic price? (high school, Croatia, in EU for 5 months)
Offline hans
« Reply #18 on: December 03, 2013, 09:05:57 am »
It may also be worth checking out Papilio:
http://www.seeedstudio.com/depot/index.php?main_page=advanced_search_result&search_in_description=0&keyword=papilio&x=0&y=0
You can compile with the free Xilinx tools and use the small Papilio loader utility to upload it to the board via USB. The USB connection are just 2 COM ports, where one is configured as JTAG for programming the FPGA, and the other is connected as a serial port for your own debugging.
For beginners it boasts decent FPGA and there are lots of open source projects around. Not all of them are in VHDL, but I think most of them are from their website.
Offline mrflibble
« Reply #19 on: December 03, 2013, 10:48:11 am »
Or just pick a board with a non-ancient fpga from joelby's list. Papilio is decent, but not the best bang for buck IMO. Anyways, the OP didn't mention any specific goals or a budget, so hopefully the list will help in finding something for his unwritten requirements. :)
Since budget may be an issue, how about the $25 icestick from Lattice? Have one myself, and it's pretty good value for money. Tools are free too. Synplyfy pro based, pretty impressive actually for that price (free XD).
Offline Fantasma25
  • Country: mx
« Reply #20 on: December 03, 2013, 04:33:54 pm »
What I recommend is to first use a simulator (like the student edition of Active HDL, which is free  8) ) and try to make combinational circuits which are almost always synthesizable, then move on to a little bit more complicated sequencial circuits (using discrete Flip Flops, not processes). That way you will learn the most basic stuff about the language and you will get used to it. Then I will suggest you to buy a cheap board like the basys 2 that has a lot of fun switches and LEDs. With a board you can try to use processes and all that stuff that is more tricky to synthesize.  :-BROKE
Offline owiecc
    • Google scholar profile
« Reply #21 on: December 03, 2013, 07:40:48 pm »
We use Digilent CoolRunner-II CPLD Starter Board for only $37 per board.
Offline mrflibble
« Reply #22 on: December 03, 2013, 08:10:56 pm »
While that's a nice board (have one myself), I'd advice against a cpld board like that as a starter board. Why? *poof!* What was that? That was the sound of your flip-flop resources running out. With a cpld like that you'll run into resource limitations real fast, and as such you are really limiting your learning experience.
Offline filip_cro
  • Country: hr
« Reply #23 on: December 04, 2013, 06:03:45 pm »
Ok. I decide to try Actin HDL (student edition). I made basic code. How can I test it? I can't find good tutorial on google.
Offline Fantasma25
  • Country: mx
« Reply #24 on: December 04, 2013, 06:45:29 pm »
Once you have written your code, you have to compile it (Design -> Compile).
If you don't have any errors, then you can simulate. First you have to initialize the simulation (Simulation -> Initialize simulation). If it is your first time you initialize that project, a windows will pop up asking you to select the code you want to simulate.
Then, all your I/O, signals, variables, constants, etc. will appear on the lower left hand side of the screen.
After that, you should click on the icon next to the save button to open the waveforms window, where you will see your signals. Then add the signals you want to see by dragging and dropping them to the waveform window.
Then you should add some stimulators to the inputs. You do that by right clicking the the signal and selecting "Add stimulators". There you can add a clock signal, a constant value and many other things depending on the circuit and on what you want to see. If its a combinational circuit, I recommend to add clock signals with frequencies that are multiples of each other.
Finally, enter the time of the simulation and click on "Run for" (F5).
Have fun! 8)
