Thank you all for your input.
Some random replies:
Evidently, on Windows at least, disabling the USB global interrupt doesn't break anything - for the current flash write period which is about 15-17ms (writing 512 bytes at a time, and at a measured 33kbytes/sec). So it is certainly not the case that after 3ms it bombs out.
I am using FreeRTOS, and apart from init in main() etc, almost everything runs under that. I am fairly familiar with it, and yes it's a wonderful way to write software. In fact I wrote my own RTOS, from scratch, for a Z180 c. 1986 and then a better one for a Z280 in 1988 which ran a pretty complex datacomms product. Software rapidly gets truly horrible without an RTOS.
USB is set up as an RTOS task and then runs mostly under interrupts, which appears to be ST's intention given that they supplied the code
IMHO the only point of argument here is that the flash write is also done inside the ISR, but (as I posted above) if one wasn't doing that, say one was farming out the flash write to a one-shot RTOS task, then one needs to get that RTOS task to return a suitable USB response (instead of the ISR doing it) and return that response only when the flash write is finished.
Re disabling flash access when a USB cable is inserted, that's a bit drastic
This product one doesn't need super performance, and one could never get "performance" anyway with a 15-17ms flash write time
(which translates to a totally crappy but in this case perfectly adequate 33kbytes/sec write speed, and the 21mbps SPI speed limits the read speed to a measured ~1.5mbyte/sec).
