Does the Stager vS4800 support that 40 pins atf2500?
if not, what other programmer support that 40 pins atf2500?
The latest version of TL866II Plus software has added support for ATF22V10.
The guy behind this can add support to a chip if you can send him some samples for him to test on.
I have built prototype hardware for the AVR GAL programmer, and am now debugging the firmware. I refactored the code and expanded it to support ATF16V8 and other GALs, and also added back in some features from GALblast that the author of Burnit had removed. This has taken a bit longer than I expected.
The ATmega328 only has 2K RAM so all static data is placed in ROM, and the (up to 5896 bit) fusemap is stored as individual bits in an array of 737 Bytes (unlike GALblast which uses 1 byte per fuse bit. Oh the joys of PC programming, where RAM is plentiful so you can afford to waste it!). This would be no problem in assembler, but C doesn't support bit arrays directly and AVR GCC has some issues with arrays in ROM. It took me 3 days to figure out why the config array wasn't working. Turns out that just declaring the array as PROGMEM wasn't enough, I also had to access the array elements with pgm_read_word(). If I didn't the compiler generated no warnings, but read from the wrong address!
Hi Bruce, Any further updates on this project? I think there would be a fair bit of interest in this.
PLD support is now looking quite good.
Test vectors seems to be missing, so I asked them to add that & I've sent them an example Test Vector file for ATF16V8
They can do IC test on logic, so the building blocks are already there, so PLD test vectors should be possible.
Are you in touch with the manufacturer?
Any chance they could add support for the ATF15xx CPLDs?
(Yes I know, these are old... But they nicely bridge the gap between PLDs and FPGAs. And they are the last parts still in production which have 5V supply versions and PLCC packages. One of their major drawbacks is that the "official", single-purpose USB adapter from Atmel and Kanda seems like the only available tool to program them.)
That would be very awesome if doable.
I don't want to waste money building a programmer if it's unlikely to work.
Use 4k7 resistors to connect all VIL pins to the GND pin (we use 4k7 instead of the 10k mentioned in other documents, because some GALs have internal pull-ups of only 50k and illegal input states would occur using 10k resistors). Use 4k7 resistors to connect all other pins (including GND and EDIT) to the VCC pin to prevent open inputs during programming.
