Author Topic: Digital Clock code  (Read 2047 times)
Offline radhikaTopic starter
  • Country: in
Digital Clock code
« on: January 24, 2019, 11:17:05 am »
I am building digital clock code. I have followed this link http://saeedsolutions.blogspot.com/2015/06/pic16f877a-based-digital-clock-using.html
I am using PIC8F4520 and OLED display.
I understand the logic and made changes in code. But, when I upload this code in Proteus, Their is nothing on OLED.
Can you suggest me that is SSD1306_PutC is right command to display time or not and what else are changes I HAVE TO MAKE?
#include "Includes.h"
#include <SSD1306.c>
#include "Timer.c"
#include "ISR.c"
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock = 20MHz)
#use I2C(MASTER, I2C1, FAST = 400000, stream = SSD1306_STREAM)  // Initialize I2C
void DisplayTimeToLCD(unsigned int,unsigned int,unsigned int,unsigned char);
int h, m, s;
char State;
// Main Function
void main(void)
   unsigned char State = NORMAL_STATE;      // To store current state
   set_tris_d(0x8c); // set direction registers of bits RD2,RD3,RD4 to be input button RD2
    // Initialize the SSD1306 OLED with an I2C addr = 0x7A (default address)
    SSD1306_Init(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS);
    // clear the display
    SSD1306_ClearDisplay();
   Init1msecTimerInterrupt();      // Start 1 msec timer
   while(1)
      if(State == NORMAL_STATE)
         if(input (PIN_D2))            // If 'Set Time' button pressed
            State = CONFIG_HR_STATE;   // Change state to Hr config
            while(input (PIN_D2))         // Wait for button to be released
               UpdateTimeCounters(State);// Keep updating time counters
      else               // If state is not NORMAL_STATE
         if(input (PIN_D3))         // If Up button pressed
            while(input (PIN_D3))      // Wait for button to be released
            switch(State)   // Increment counter
            case CONFIG_HR_STATE:    hrCounter++;   break;
            case CONFIG_MIN_STATE:   minCounter++;   break;
            case CONFIG_SEC_STATE:   secCounter++;   break;
         else if(input (PIN_D7))      // If Down button pressed
            while(input (PIN_D7))      // Wait for button to be released
            switch(State)   // Decrement counter
            case CONFIG_SEC_STATE:   if(secCounter==0)
                                 secCounter = 59;
                              else
                                 secCounter--;
                              break;
            case CONFIG_MIN_STATE:   if(minCounter==0)
                                 minCounter = 59;
                              else
                                 minCounter--;
                              break;
            case CONFIG_HR_STATE:    if(hrCounter==0)
                                 hrCounter = 23;
                              else
                                 hrCounter--;
                              break;
         else if(input (PIN_D2))      // If 'Set Time' button pressed again
            switch(State)   // Shift to next state
            case CONFIG_HR_STATE:    State = CONFIG_MIN_STATE;   break;
            case CONFIG_MIN_STATE:   State = CONFIG_SEC_STATE;   break;
            case CONFIG_SEC_STATE:   State = NORMAL_STATE;      break;
      UpdateTimeCounters(State);       // Update sec, min, hours counters
      if( msCounter == 0 )    // msCounter becomes zero after exact one sec
         // Display time in HH:MM:SS format
         SSD1306_GotoXY(6, 4);
         DisplayTimeToLCD(hrCounter, minCounter, secCounter, NORMAL_STATE);
      else if( msCounter == 500 && State != NORMAL_STATE )
         // Display time with either HH or MM or SS missing
         // according to the State, to create an animated experience
         DisplayTimeToLCD(hrCounter, minCounter, secCounter, State);
// Displays time in HH:MM:SS format
void DisplayTimeToLCD( unsigned int h, unsigned int m, unsigned int s, unsigned char State )
   SSD1306_ClearDisplay();     // Move cursor to zero location and clear screen
   if(State == CONFIG_HR_STATE)
      SSD1306_PutC( ' ' );   // Display Spaces
   else
      SSD1306_PutC( (h/10)+0x30 );   // Display Hour
      SSD1306_PutC( (h%10)+0x30 );
   //Display ':'
   SSD1306_PutC(':');
   if(State == CONFIG_MIN_STATE)
   else
      SSD1306_PutC( (m/10)+0x30 );   //Display Minutes
      SSD1306_PutC( (m%10)+0x30 );
   //Display ':'
   SSD1306_PutC(':');
   if(State == CONFIG_SEC_STATE)
   else
      SSD1306_PutC( (s/10)+0x30 );   //Display Seconds
      SSD1306_PutC( (s%10)+0x30 );
Offline Doctorandus_P
Re: Digital Clock code
« Reply #1 on: January 24, 2019, 12:25:06 pm »
If your OLED display does not work in Proteus, then simplify things.
Make a new project (or copy the clock project) and remove all clock related stuff.
Start by printing a line of text on the display, or even a single pixel.
If you can draw a pixel, then you know that the simulator works, the schematic in the simulator works, and a whole bunch of other stuff on some low hardware like levels.
Once you have a working foundation start addding more complicated stuff.
  • Country: in
« Reply #2 on: January 24, 2019, 04:59:40 pm »
Its working fine, but for this code its not displaying anything
