Author Topic: error writing program  (Read 1507 times)
Offline nassihTopic starter
  • Country: ma
« on: December 25, 2023, 11:04:32 am »
hi every on ,i have exported binary file from target memory of tms320f280 using uniflash jtag mode with xds100,the problem is when i want to load the file on another chipe i have an error ([WARNING] C28xx: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map)
Offline jpanhalt
Re: error writing program
« Reply #1 on: December 25, 2023, 11:29:24 am »
I am not familiar with your system; however, that's the sort of error MPLab 8.92 might give if the configuration of the programmer/assembler is set to a different chip than the one for which the code was written.
  • Country: ma
« Reply #2 on: December 25, 2023, 11:59:15 am »
tanks for reply,I am not familiar with this jobs but need help,I spent several months looking for a solution to finish this operation, but without success. I am a technician on the hardware side and I know nothing about the software side except basic things.tanks
