Thanks for your replies. Here's my code for UART:
module uart(
clk,
tx,
data,
send_req, //this would be high for one clock period
sent,
tx_busy,
//debugging purposes
transmit_flag,
state,
tick,
count
input clk;
input data;
input send_req;
output count;
output tick;
output state;
output transmit_flag;
output tx;
output sent;
output tx_busy;
reg[14:0] count;
reg[3:0] state;
reg muxbit;
reg[7:0] tx_data;
reg start;
reg transmit_flag;
reg tx_busy;
reg sent;
wire[7:0] data;
wire tick;
initial
begin
/*sent <= 0;*/
transmit_flag <= 0;
tx_busy <= 0;
count <= 0;
end
//baud rate generator:
always @(posedge clk)
begin
count<=count+1;
if(count == 5208)
count <= 0;
end
assign tick = (count==5208);
//manager
//always @(posedge clk)
//begin
// if((send_req)&(~tx_busy))
// begin
// tx_data <= data;
// transmit_flag <= transmit_flag + 1;
// end
// if(done)
//end
//transmission
always @(posedge tick)
begin
begin
tx_data <= data;
end
case(state)
4'b0000: begin
sent <= 0;
if(transmit_flag)
begin
tx_busy <= 1;
transmit_flag <= transmit_flag - 1;
state <= 4'b0100;
end
end
4'b0100: begin state <= 4'b1000; end // start
4'b1000: state <= 4'b1001; // bit 0
4'b1001: state <= 4'b1010; // bit 1
4'b1010: state <= 4'b1011; // bit 2
4'b1011: state <= 4'b1100; // bit 3
4'b1100: state <= 4'b1101; // bit 4
4'b1101: state <= 4'b1110; // bit 5
4'b1110: state <= 4'b1111; // bit 6
4'b1111: state <= 4'b0001; // bit 7
4'b0001: begin state <= 4'b0000; tx_busy <= 0; sent <= 1; end// stop1
default: state <= 4'b0000;
endcase
end
always @(state[2:0])
case(state[2:0])
0: muxbit <= tx_data[0];
1: muxbit <= tx_data[1];
2: muxbit <= tx_data[2];
3: muxbit <= tx_data[3];
4: muxbit <= tx_data[4];
5: muxbit <= tx_data[5];
6: muxbit <= tx_data[6];
7: muxbit <= tx_data[7];
endcase
// combine start, data, and stop bits together
assign tx = (state<4) | (state[3] & muxbit);
endmodule
A signal send_req from the top level module will activate it. Sure, but I want to change it so I could control this module to be executed just once or an x number of times.
Any help would be appreciated.
