Author Topic: Help identify unknown MCU 44pin  (Read 5258 times)
Offline bootmodeTopic starter
  • Country: ga
« on: July 22, 2026, 01:41:50 pm »
I have an IC with a laser-removed marking and I'm trying to identify the manufacturer by the logo.
What I can read:
Marking (partial, heavily lasered): "8HF5102", "A0", "132" (datecode)
Logo: Triangle shape with a curved element inside (see photo)
Electrical characteristics (measured):
Package: TQFP44, 10x10mm
Pin 16 → GND (only GND pin)
Pin 38 → VCC 3.3V (only VCC pin)
Pin 21 → RESET (connected to button on PCB)
All I/O pins have ~5kΩ pullup to VCC → classic 8051 behavior
6-pin ISP header (P3):
Pin 1 → VCC
Pin 2 → RESET
Pin 6 → GND
Pin 3, 4, 5 → unknown (likely UART ISP)
Photos of logo and PCB attached.
Any help appreciated!
Offline TbayBoy
Re: Help identify unknown MCU 44pin
« Reply #1 on: July 22, 2026, 02:16:09 pm »
2 antennas got married... the ceremony was lousy but the
reception was excellent...
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #2 on: July 22, 2026, 02:30:55 pm »
89E5102?
89S5102?
MCS-51?
  • Country: ga
« Reply #3 on: July 22, 2026, 03:58:40 pm »
no this has nothing to do with it
but thanks
  • Country: ga
« Reply #4 on: July 22, 2026, 08:33:33 pm »
i am not sure
i even cant find the logo
Online daisizhou
  • Country: cn
« Reply #5 on: July 23, 2026, 06:51:25 am »
What I can read:
Pin 1 → VCC
Pin 2 → RESET
Pin 6 → GND
If you can afford to lose this MCU, I suggest you remove the outer black packaging layer until you see the internal crystal, where the exact model number might be printed.
daisizhou#sina.com #=@
Offline uer166
« Reply #6 on: July 23, 2026, 07:11:20 am »
Can you post more of the PCBA/circuitry around it?
Offline PCB.Wiz
« Reply #7 on: July 23, 2026, 08:03:34 pm »
What I can read:
It might also say 89F51 and maybe it is 89F51U2 ?
 There are a lot of 8051 vendors in Asia and what is visible of the logo is not very clear.
How old is the product and what is your desired next steps?
 It is not trivial to get code from a secured 89F51
Offline PCB.Wiz
« Reply #8 on: July 23, 2026, 08:09:52 pm »
For fun AI finds this answer from left field…
Mercedes-Benz made the 89F51 with the SL prefix, referring to the R 129 series SL Roadster.
Offline thm_w
  • Non-expert
« Reply #9 on: July 24, 2026, 02:06:30 am »
Context would help from the OP, if they said what device it is.
  • Country: ga
« Reply #10 on: July 24, 2026, 10:34:44 pm »
the pcb ist from 2015
i would like to dump the mcu
its from an extra pcb to write into a nxp lpc
Offline thm_w
  • Non-expert
« Reply #11 on: July 24, 2026, 11:05:10 pm »
and the product its from, you saying its a lpc programmer?
  • Country: ga
« Reply #12 on: July 24, 2026, 11:36:13 pm »
the pcb is from china no name
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #13 on: July 27, 2026, 02:57:04 am »
FWIW it looks like the power pins line up with an STC89 44-pin.
https://www.stcmicro.com/datasheet/STC89C51RC-en.pdf
“They Don’t Think It Be Like It Is, But It Do”
  • Country: ga
« Reply #14 on: August 01, 2026, 02:29:00 am »
i tried several stuff and tools but i get no communication
any ideas about the protocol?
Online Psi
« Reply #15 on: August 01, 2026, 04:12:58 am »
The triangle logo and the AU on the last line followed by a number makes me think of a really old Atmel.
Lots of ATMEL stuff had AU on the end.
Maybe they didn't put AT at the start long ago. So AT89S51 might have been 89S51
Also AT89S51 in 44-lead TQFP package has the right pin out
Pin 16 → GND
Pin 38 → VCC
Reset is pin 4 though, not 21. But maybe that isnt a reset button.
Check if pin 16 and 17 are shorted, they should both be GND.
But programming would be done on MCU pins 1,2,3,4  where do they go on the PCB?
https://ww1.microchip.com/downloads/en/DeviceDoc/doc2487.pdf
« Last Edit: August 01, 2026, 04:34:20 am by Psi »
Offline Unixon
« Reply #16 on: August 01, 2026, 10:33:20 am »
This small board is a part of automotive programmer KTAG KTM100, comes attached on top of the main board.
« Last Edit: August 01, 2026, 11:08:59 am by Unixon »
Offline Unixon
« Reply #17 on: August 01, 2026, 11:08:41 am »
Main chip on the bottom board is LPC2478FBD208 and this small top board is plugged into this 8-pin connector in the front (see red board).
Can't tell it by the traces, but this connector is close to JTAG interface of LPC.
However, JTAG connector probably goes into this huge unpopulated SMD footprint on the left and 8-pin is probably UART + something else (why does it need 8 pins?).
What is this small board doing? Putting main MCU in some kind of debug mode?
Other than 8-pin connector there's only power and a tact switch attached to it.
« Last Edit: August 01, 2026, 11:17:11 am by Unixon »
The following users thanked this post: Fraser
Offline Unixon
« Reply #18 on: August 02, 2026, 12:05:32 pm »
No traces from 8-pin connector on the bottom side, but I see a couple of vias.
This is likely a 4-layer board, so many things are hidden on inner layers.
I thought that maybe tracing this interface could help to identify MCU on the top board by pinout.
Offline Uunoctium
« Reply #19 on: August 02, 2026, 03:38:32 pm »
tl;dr
As far as i found out, these ECU programmers  supporting GPT*  Functions ( GPT is new password algo cryptography that is implemented in new Tricore microcontrollers from Infineon.)
They are capable to decrypt passwords and afterwards automatically opens protected sectors of ECU temporarily. So user has an read/write access.
1st gen versions needed an additional adapter for this, the newer having this function buildt in. It's the small green PCB.
The newest gen multiplexers are advertised as "4-LED" model with "red PCB".
*general purpose timer
  • Country: ga
« Reply #20 on: August 02, 2026, 11:12:29 pm »
the extra pcb is used for resetting the flash counter so you dont have to update the device
Offline voltsandjolts
« Reply #21 on: August 03, 2026, 09:23:29 am »
Ah, I see.
The KTAG programmer limits the number of ECUs you're allowed to program.
Then you're supposed to buy more programming 'credits'.
But this hack device (piggyback board) can do that for you, and give you more programming credits for free.
And you want to hack the hack device. :-+
https://bhadraelectronics.com/blogs/f/v225-ktm100-ktag-ecu-programming-tool-with-reset-button
« Reply #22 on: August 03, 2026, 09:27:21 am »
Pin 1 → VCC
Pin 2 → RESET
Pin 6 → GND
I would expect those unknown pins go to PSEN, RX, TX
Which MCU pins connect to which P3 header pins?
Online Psi
« Reply #23 on: August 03, 2026, 10:21:50 am »
Pin 1 → VCC
Pin 2 → RESET
Pin 6 → GND
You can see in the last image, 3,4,5 on P3 are 20,19,18 on mcu
« Last Edit: August 03, 2026, 10:24:07 am by Psi »
The following users thanked this post: voltsandjolts
Offline DavidAlfa
« Last Edit: August 13, 2026, 10:38:05 am by DavidAlfa »
The following users thanked this post: voltsandjolts, PCB.Wiz, Uunoctium, bootmode
