While there are MILLIONS of uses for low end (cheap) and very low end (very cheap) microcontrollers, there are limited number of applications that require a "solution" based on just a few ICs (NOT boards). Specifically I am thinking about Powertrain (engine and transmission) Control Modules (PCM). The requirements are very broad.
On board/fast 5V ADC
They are not fast in the sense of fast ADCs.
External digital event capture/interrupt
Nothing in an engine requires timing faster than that which could be handled by an external interrupt.
Floating point
Nothing in an engine requires floating point, but most programmers do not know how to used fixed point math. There used to be compilers which kept track of the radix of fixed point math.
Reasonably fast
The processors used for engine control systems have performance orders of magnitude higher than needed.
Looking for suggestions.
Hardware is cheap and programming time is expensive. I usually look for parts which have the most build in RAM, but ROM size can be important also.
Not sure if you are familliar with the ECUs produced in the last 10 years
Besides the increased number of sensors, you have to make guarantees on timings, significant signal processing is done inside, some brands now don't even use maps anymore, because they have enough processing power to run the various algorythms and models that are approximated by maps. Whatever bosch has been putting out since 2018 has 4 dual lockstep cores, virtualization, runs several ECUs as VM and compare the results of each.
This is mid/high end cars (think anything audi and mercedes with a 2.0 or bigger engine)
Lower end cars have much simpler ECUs, but some advanced functions (related to emission controls) are delegated to separate modules
