Author Topic: High end embedded controller ICs  (Read 3232 times)
Offline theoldwizard1Topic starter
« on: November 23, 2025, 10:43:42 pm »
While there are MILLIONS of uses for low end (cheap) and very low end (very cheap) microcontrollers, there are limited number of applications that require a "solution" based on just a few ICs (NOT boards).  Specifically I am thinking about Powertrain (engine and transmission) Control Modules (PCM).  The requirements are very broad.
  • On board/fast 5V ADC
  • External digital event capture/interrupt
  • Floating point
  • Reasonably fast
    • On board RAM
    • On board Flash
On board RAM and Flash are subordinate to "fast" because moving these off chip slows the processor down.
The real issue is RAM and Flash requirements are "moving targets" !  They never shrink, but do constantly grow !
Looking for suggestions.
Offline David Hess
  • DavidH
Re: High end embedded controller ICs
« Reply #1 on: November 23, 2025, 11:36:50 pm »
They are not fast in the sense of fast ADCs.
Nothing in an engine requires timing faster than that which could be handled by an external interrupt.
Floating point
Nothing in an engine requires floating point, but most programmers do not know how to used fixed point math.  There used to be compilers which kept track of the radix of fixed point math.
Reasonably fast
The processors used for engine control systems have performance orders of magnitude higher than needed.
Hardware is cheap and programming time is expensive.  I usually look for parts which have the most build in RAM, but ROM size can be important also.
The following users thanked this post: Buriedcode
Offline PCB.Wiz
« Reply #2 on: November 24, 2025, 02:31:20 am »
That's a very broad/vague laundry list, ('fast' is meaningless without a number) but google finds a good list from the usual suspects
with this simple search
fastest MCU with 5V operation and FPU
Powertrain (engine and transmission) Control Modules (PCM) is a large enough market, for many vendors to chase it.
Online aeg
« Reply #3 on: November 24, 2025, 03:18:01 am »
The ECU in my car has an 18MHz 8051 with 2304 bytes of RAM, one ADC and a few timer/counters. That handles fuel management, ignition timing, injector timing, boost control, idle air control, catalyst monitoring, and so forth.
  • Floating point
oh hell no
Offline David Hess
  • DavidH
« Reply #4 on: November 24, 2025, 05:25:27 am »
  • Floating point
oh hell no
It is easier to just accept hardware floating point support and use it.  Specialized compilers used to have fixed point support, but it never became a standard.
Offline AVI-crak
  • Country: ru
    • Rtos
« Reply #5 on: November 24, 2025, 08:09:32 am »
Use double precision, that should help.
Offline JPortici
« Reply #6 on: November 24, 2025, 08:20:41 am »
Floating point
Reasonably fast
Not sure if you are familliar with the ECUs produced in the last 10 years
Besides the increased number of sensors, you have to make guarantees on timings, significant signal processing is done inside, some brands now don't even use maps anymore, because they have enough processing power to run the various algorythms and models that are approximated by maps. Whatever bosch has been putting out since 2018 has 4 dual lockstep cores, virtualization, runs several ECUs as VM and compare the results of each.
This is mid/high end cars (think anything audi and mercedes with a 2.0 or bigger engine)
Lower end cars have much simpler ECUs, but some advanced functions (related to emission controls) are delegated to separate modules
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #7 on: November 24, 2025, 10:01:51 am »
Last week i received EMails with ads on STM32N6 technology that is to appear for sale in 2026 or 2027. As an elderly person who started with a DIY 8085 computer: the specs are really amazing. Appearently the requirements of cellular phones have driven computing a lot and we can nowadays use 32 or 64 bit technology in cheap battery driven devices, even including some AI.
I can't quite get the meaning of the original post. And please don't start discussing 50 year old 8 bit technology. Get an STM32H743 evaluation board or something similar from another supplier and start your journey. It will take some time to get familiar. Those modern chips have all kinds of ready to use serial and parallel data interfaces. They are able to capture digital video (and of course the data stream of other fast ADCs).
Regards, Dieter
« Last Edit: November 24, 2025, 11:09:24 pm by dietert1 »
The following users thanked this post: pardo-bsso
Online uer166
« Reply #8 on: November 24, 2025, 10:46:38 pm »
Suggestions for what? Based on the list of requirements, you don't yet understand what a ECU/engine controller actually requires. I would start researching actual control/sensor requirements and compute, and go from there.
In the EV space, realtime control of a drive motor is much faster than a ICE generally for e.g. current control loops through windings, and in that space it's usually some flavor of TMS320 doing the hardcore DSP, and for the body controls/general purpose ECUs, it is much slower MPUs like SPC560 (powerPC). I don't have personal experience with ICE vehicles, but I'm sure they have a similar kind of split/horses for courses.
Offline Andy Chee
« Reply #9 on: November 25, 2025, 07:51:39 am »
Many engine control units ECUs from vehicles made in the 1980s-1990s used a 68HC11 microcontroller.
If your old car's 68HC11-based ECU died for any reason, you could probably run such an engine from an Arduino or ATmega328 if you wanted!
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #10 on: November 25, 2025, 02:32:13 pm »
Abuot 13 years ago i designed a control system for two active audio speekers = six actuators operating at a 96 KHz sampling rate. The channel program of the DSP hat about 700 instructions and ran on a Cortex M4 at 120 MHz. The biquads used for filters were handcoded using Cortex M DSP instructions, e.g. 32 x 32 bit multiply with 64 bit accumulate all in one cycle.
As far as i remember there are Cortex M7 MCUs that run at 5x the clock rate. Those MCUs are cheap and include very complex timer peripherals optimized for rotating motor control.
Regards, Dieter
« Last Edit: November 25, 2025, 09:32:58 pm by dietert1 »
Offline eugene
« Reply #11 on: November 25, 2025, 03:30:46 pm »
  • Floating point
  • Reasonably fast
    • On board RAM
    • On board Flash
I don't think you've taken the time to flesh out the actual requirements. By that I mean real numbers in terms of timing and memory requirements etc. Intuition and guessing isn't going to get you there.
Megasquirt has been selling ECU kits for a very long time. The original Megasquirt (c1999) used an 8 bit MC68HC08 with an 8MHz bus, 32k flash and 512 bytes of RAM. That's actually quite a bit less than the original Arduino Uno. As hard as it might be to believe, this MCU could read all of the necessary sensors (at the time) and control both ignition and fueling of a V8 engine.
Take a look at the open source rusEFI. It uses an STM32 and manages to do all of the amazing things you seem to think are necessary.
90% of quoted statistics are fictional
Offline langwadt
« Reply #12 on: November 25, 2025, 03:48:09 pm »
except for 5V adc those requiments are easily meet by most "modern" MCUs
Offline Warhawk
    • Personal resume
« Reply #13 on: November 25, 2025, 08:09:52 pm »
  • Floating point
  • Reasonably fast
    • On board RAM
    • On board Flash
C2000 :-)
Online SiliconWizard
« Reply #14 on: November 25, 2025, 08:21:47 pm »
Anything Cortex-M7 (or maybe even -M4) based should fit. Your "only" problem is this 5V thing, but I'm sure you're fully aware of that cutting you off a ton of options.
Offline westfw
« Reply #15 on: November 25, 2025, 08:37:58 pm »
And WHY 5V for the ADC, anyway?
Aren't analog signals essentially trivial to scale to whatever range is appropriate?
There are "many" current microcontrollers aimed at "motor control."  Mostly targeting efficient control of  3phase electrical motors, but I suspect the performance/sensing requirements are quite similar.
And of course there are processors aimed specifically at the automotive market.  Their documentation is just less "public", unless you're actually IN the automotive business.  :-(
Offline Andreas
« Reply #16 on: November 25, 2025, 09:20:26 pm »
Hello,
of course you can run a engine with a 8 bit controller.
But the exaust gas requirements nowadays need many sensor and actor correction and learning functions (e.g. knock control, tooth angle adaption) to reach the exhaust targets.
And the trend is replacing hardware by software modules.
a typical controller is a multicore device like one of these
 https://www.infineon.com/products/microcontroller/32-bit-tricore
And believe me: if the device would cost 1 cent less (times 1 million devices) without floating point the car manufacturers would get a chip version without that if they wouldnt need it.
with best regards
Andreas
Online uer166
« Reply #17 on: November 25, 2025, 09:27:51 pm »
Yes, and that's how you do it on actual production vehicles too: even if your MCU core/ADC is running at 1.8V say, you give the sensor 5V to power it and scale down the output to ADC range that you need.
The whole 5V sensor thing is mainly a legacy aspect of it anyway, though scaling down a higher voltage does bring some SNR benefits. Many slow sensors now sit directly on LIN or CAN bus, so a digital interface; this only works for slower signals like temperature or voltage or perhaps MAF sense..
Offline Andreas
« Reply #18 on: November 25, 2025, 09:32:29 pm »
Unfortunately it is not trivial to get 12 bit precision over a temperature range of -40 .. +125 deg C with a (moderate cost) 100 ppm/K resistor.
And the sensor supply for ratiometric sensors is still mostly 5V.
Online uer166
« Reply #19 on: November 25, 2025, 09:39:56 pm »
This is why slow sensors have integrated ADC where it makes sense, you're not converting it yourself.
Besides, level shifting doesn't need an absolute tolerance, only a matched ratio resistor network which is cheap and trivial. 5-20ppm is available for cents.
Offline langwadt
« Reply #20 on: November 25, 2025, 11:33:21 pm »
Hello,
none of that needs triple core cpus with all kind of bells a whistles, compared to any current MCU the needs of a combustion engine is slow
