Author Topic: Interface compact flash to Processor memory interface  (Read 1491 times)
Offline rakeshm55Topic starter
« on: March 22, 2019, 04:56:34 am »
How to interface compact flash to memory interface of a processor?? eg GPMC interface
Is the interface similar to NAND??...
How hard is it to bring up the interface
Please share some example designs for the same... If OS like linux in involved is it advisable to choose such an interface for Kernel as long as there is no support??
Offline viperidae
Re: Interface compact flash to Processor memory interface
« Reply #1 on: March 22, 2019, 05:13:40 am »
Compact flash uses a standard ATA interface like an old ide hard drive
« Reply #2 on: March 22, 2019, 07:34:33 am »
Wont it allow for 8bit 16 bit access from Host machine??  other than true IDE mode
PC Card Memory Mode, PC card IO mode
like Common Memory Mode or I/O mode
http://pdf.datasheetcatalog.com/datasheet/MitsubishiElectricCorporation/mXyzqtuu.pdf
Offline legacy
« Reply #3 on: March 22, 2019, 10:25:41 am »
CF-ATA, electrically it's the same, but it's a subset of the protocol.
I know because we (at DTB) are using a router for a project with a CF interface, and ... we had to modify the ata-kernel-module with patches specific for the CF-ATA.
