For all the Python haters, yes.. you can design hardware with Python - http://www.myhdl.org
As if VHDL and Verilog weren't confusing enough, now we have another HDL to learn.
What advantages does MyHDL have over the other two?
All these High Level Synthesis (HLS) HDLs seem to have common threads to address these (and other) problems:
- Couldn't hardware design it be more like programming?
- The level of abstraction in HDLs is too low
- I don't want to micromanage bits - I just want it to work like integers and floats
- Productivity of HDLs is too low - e.g. testing through simulation is slow.
- I want to use programmers, not hardware designers
I have played with a couple.
- "It can't be more like programming?". There is a solid barrier that makes one not like the other. Programming updates a little bit of data every cycle. To make the most of FPGAs you can not use them like that, you need to make pipelines and have data flow through your design in a way programming can't do.
- "The level of abstraction in HDLs is too low". You can break out of low level HDL programming if you want, but at the cost of doing things somebody else's way, and most likely paying a lot for IP blocks that are huge, complex and costly. However if your needs are unique, then you need to work at low levels of abstraction, for at least part of the design. The 80/20 rule applies
- "I don't want to micromanage bits" - If you want to burn through FPGA resources at an alarming rate, and have minimal performance, all your 'variables' can be 64-bit integers. Sometimes the tools will pick up a reduced range and optimize unused bits way, sometimes it wont. The tighter you constrain the design (e.g. size of counters) the better the design will perform.
- "Productivity of HDLs is too low compared to programming" - Very valid. Being able to efficiently test designs like software is awesome. But then you have to verify that the resulting design actually is equivalent to the software...
- "I want to use programmers, not hardware designers" - If the programmer can't envisage what the design will look like in hardware, then they are just fumbling around in the dark. They will spend a lot of time trying to find an efficient way to express what they are trying to do in a way that the tool set likes and produces an efficient design.
In short - it seems to be great when cost is no object (e.g. research), performance is no object (e.g. research) and rapidly testing new things (e.g. research).
You can also paint yourself into a dead end. If your design tests out ok, fits into the target chip, but does not meet timing requirements then what can you do? You need a skilled HDL coder to to re-write the slow bit.
For some commercial use it is also workable, but requires a skilled hardware designer who knows the HLS tools and the problem space intimately, rather than a generic C/Python/whatever hack.
So in short it ends up with high-level code that is written in a quirky, ungainly way, but a 'normal programmer' can read and maybe make sense of - but a normal programmer will have minimal understanding of why it is like that. A single "refactor" of a module to make it "more normal" will break everything.
