Late breaking news: The board has shipped - from Mouser. The very place I looked for stock. I must have had a serious bout of 'senior moments' yesterday!
p.s.
why Lattice? Never used, I am curious.
p.s.
For the equivalent sized parts to those offered by Xilinx or Altera I don't think that Lattice necessarily offers parts with any particular advantages. Where I think they have a winner is in the ICE40 range where there are a number of FPGAs in the £3-5 bracket (one off prices) with 1k to 8k LEs/cells/pick-your-own-terminology available in prototyping friendly QFP and QFN packages.
p.s.
For the equivalent sized parts to those offered by Xilinx or Altera I don't think that Lattice necessarily offers parts with any particular advantages. Where I think they have a winner is in the ICE40 range where there are a number of FPGAs in the £3-5 bracket (one off prices) with 1k to 8k LEs/cells/pick-your-own-terminology available in prototyping friendly QFP and QFN packages.Not familiar with ICE40 but an advantage of the XO2 family is onboard flash, plus core voltage regulator, and even an internal oscillator, so they are very useable on 2-layer PCBs with no additional support parts - just a 3.3v supply, a JTAG header and off you go.
If you have the possibility ( = if your boss/customers pay it ), switch to Sigasi. It's the Eclipse-like for HDL
p.s.
Some, but not all, of the ICE40 range have those features with the exception of an on-board core voltage regulator - they need a nominal 1.2V plus whatever your I/O standard requires. Lattice have always been good at integrating features that get you closer to the ideal of 'just needs a supply and a programming header'. Anybody else remember their in system programmable PALs, when everybody else's PALs needed dedicated out of circuit, high voltage programming?
Would learning FPGA by writing peripherals for NIOS system be an interesting to you?
I did learn quite a lot when I was doing intern and I had to modify a peripheral of an existing Microblaze sytem to extend its functionality.
Everything else had been setup, timing constraints, pins configuration ... etc ... etc.
I only needed to work out how the bus worked and wrote simple codes to let the bus read registers and write registers. Clear registers on read ... etc
I have a project here and always need new peripherals then verification on different boards.
www.github.com/jefflieu/recon
If you've been doing software then most of the stuff should be familiar to you.
Cheers,
Jeff
Cheers,
JeffOut of interest, what's the compile/run/debug cycle time doing that? Does including the NIOS stuff add a lot ?
Cheers,
JeffOut of interest, what's the compile/run/debug cycle time doing that? Does including the NIOS stuff add a lot ?Can you please be more specific, doing what? (this could be off topic though)
When you say add a lot, if you mean resources then NIOS stuff costs about 1000 to 1500 LUs + Flops, simple CPU core and Avalon bus
If you mean add a lot of effort, then yeah, it takes some effort to setup hardware and software correctly, but not so bad.
I think if the NIOS system is setup, FPGA can be learnt by adding/creating new peripherals, especially if you're familiar with software, it'll be more interesting.
The coding for CPU peripherals is mostly RTL design I'd say.
What does Sigasi cost these days?
No I mean comparing developing a standalone function versus hanging something off a NIOS processor, what is the time penalty of the synthesize/place & route time doing the latter?
I've not used Altera, but IME with ISE and Diamond, for small designs, compile cycles of low tens of seconds are typical, and tolerable for a write/compile/debug/repeat workflow.
If adding a processor makes this a lot longer, any benefit of using a processor to simplify testing may be outweighed by the extended debug cycle times.
Awesome!!! So, who cares? Now, I am more interested in productivity since more productivity means more plants in my office, may be a bigger office with two secretaries and an aquarium with tropical fishes
I thought ICE40 had OTP memory, or are there now some flash versions?
For all the Python haters, yes.. you can design hardware with Python - http://www.myhdl.org
For all the Python haters, yes.. you can design hardware with Python - http://www.myhdl.orgAs if VHDL and Verilog weren't confusing enough, now we have another HDL to learn.
What advantages does MyHDL have over the other two?
It actually processes into VHDL or Verilog for synthesis. The site does a better job explaining the pros and cons better than I ever could.
Perhaps the Python simulation is a little faster (maybe even a lot faster) but I don't usually bother with simulation. If I did do simulation, I would use the chip vendor's simulator. It's the only opinion that matters.
- "The level of abstraction in HDLs is too low". You can break out of low level HDL programming if you want, but at the cost of doing things somebody else's way, and most likely paying a lot for IP blocks that are huge, complex and costly. However if your needs are unique, then you need to work at low levels of abstraction, for at least part of the design. The 80/20 rule applies.
- "The level of abstraction in HDLs is too low". You can break out of low level HDL programming if you want, but at the cost of doing things somebody else's way, and most likely paying a lot for IP blocks that are huge, complex and costly. However if your needs are unique, then you need to work at low levels of abstraction, for at least part of the design. The 80/20 rule applies.Well you can go to extremely high levels of abstraction in VHDL, so its possible to have a higher level language by using the existing tools better. But the core issue is that programming for simultaneous execution is radically different to programming for sequential execution.
There have been some good attempts at C-hdl and they work well at matching some patterns, but remain poor at improving all code. So even with the high level tools you still end up needing to understand the flow and patterns that fit into logic, just as if you were programming HDL to begin with.
