Author Topic: MH-M18(clone) Bluetooth module reprogramming possible?  (Read 8466 times)
Offline HerschelTopic starter
  • Country: in
« on: May 09, 2024, 02:42:26 pm »
Is there any way to remove that annoying lady announcement from this bluetooth module?
i ordered a mh-m18 bluetoothaudio recever off amazon and they send me a clone with this annoing announcement. and i noticed, instead of m18 ic, it had a   JL AS208PO1429-25C4  ic.
is it possible to disable this announcement or reprogram its firmware?
Offline Sacodepatatas
Re: MH-M18(clone) Bluetooth module reprogramming possible?
« Reply #1 on: May 10, 2024, 09:16:50 am »
Yes, the chip is an AC6925C. This is good because the JieLi chips usually are encrypted with a passkey, but the AC6925C has a flawn that lets you program a new firmware. You need a programmer that just "triggers" the USB bootloader of the chip so a new device in your PC enumerates. I cannot say much more about this topic but i can point you where to find more details.
https://github.com/kagaimiq/jielie
https://usmi.mybb.ru/viewforum.php?id=8
As a side note, the AC6925C is not a clone of the MH-M18. The MH-M18 is a relabelled AC6925C.
  • Country: in
« Reply #2 on: May 10, 2024, 10:09:09 am »
i thought this was a dead end. pretty happy to get the actual name of the ic. is it possible to get the bluetooth firmware used in the ic?
« Reply #3 on: May 10, 2024, 02:18:43 pm »
Yes, you may use this tool for reading the encrypted firmware, and programming a new recrypted one (or unencrypted if you reset the chipkey that was set by the manufacturer of the module).
https://github.com/kagaimiq/jl-uboot-tool
And the tools for managing the firmware encryption are here:
https://github.com/kagaimiq/jl-misctools
In this link there is the SDK for the AC692X
https://download.csdn.net/download/ledwin/10883331?utm_source=bbsseo
But i think such SDK is also published any place inside the USMI forum mentioned in my reply above.
Firmware is programmed using something called "Codeblocks".
« Last Edit: May 10, 2024, 02:22:17 pm by Sacodepatatas »
  • Country: in
« Reply #4 on: May 10, 2024, 02:37:34 pm »
can i use this same firmware for AC6965A bluetooth controller ic?
« Reply #5 on: May 10, 2024, 04:30:23 pm »
I don't think so, but I'm not really sure. The MCU core of the AC6965A is different from the AC6925C. Furthermore, the devices sold with the 6965A are locked and encrypted with a chip key that is only known by the device manufacturer, and the workarround for the AC6925 intended for making it blank, doesn't work for the AC6965A (I'm also already waiting for a solution for this later chip).
  • Country: in
« Reply #6 on: May 10, 2024, 04:34:54 pm »
the bluetooth module i have comes with AC6965A :palm:. but i have another bluetooth module with AC6925C with actual chinese announcement. let me try on that
