Poll
How can I test if I soldered everything well
one
3 (42.9%)
two
4 (57.1%)
Total Members Voted: 5
Author Topic: microcontroller help with testing  (Read 10207 times)
Offline ssportTopic starter
  • Country: hr
« on: February 23, 2024, 12:58:10 pm »
Thank you
« Last Edit: February 24, 2024, 05:19:04 pm by ssport »
Offline pcprogrammer
Re: microcontroller help with testing
« Reply #1 on: February 23, 2024, 01:41:06 pm »
As none of us have a crystal ball, please provide more specific information, like a schematic or pictures of what is connected together
Also the voting option you added to this thread makes no sense at all.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: February 23, 2024, 01:59:08 pm »
i am trying to connect esp32 ttgo display and dslr camera ...
That is very probably not a straightforward project, unless I'm misunderstanding your question. You need to write up a much more detailed explanation of what you are trying to do because of the likely complexity of this.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: February 23, 2024, 04:34:43 pm »
OK so the what you are connecting with is kind of irrelevant. you need to establish what is required to make the camera do what you want. normally a camera has a half press shutter button position and a full press. so have you connected all of these? depending on the camera and the settings it may refuse to fire the shutter if it has not focused. So have you checked the camera settings?
You need to supply more information.
Offline tooki
« Reply #4 on: February 23, 2024, 05:53:48 pm »
The code is okay and the pins are correct.
How do you know for sure? It’s not working, after all…
Share ALL the information about this project, including the model of camera, schematic for your wiring, and your code.
For everyone else: OP’s thread titled “soldering” has photos of the wires soldered to the ESP32 board. But without context who knows whether that’s correct as it is or not.
« Reply #5 on: February 23, 2024, 07:46:05 pm »
I looked at that other thread only to find that the images don't display on my linux system. "Error interpreting JPEG image file (Not a JPEG file: starts with 0x00 0x00)"
Maybe Windows is more forgiving  :-//
At least the voting option in that thread makes a little bit of sense.  :)
Offline tooki
« Reply #6 on: February 24, 2024, 06:39:31 pm »
Aaaand OP has deleted the content of the original post above, and deleted the images altogether. Brilliant. 🙄
The following users thanked this post: pcprogrammer
Offline SiliconWizard
« Reply #7 on: February 24, 2024, 09:00:15 pm »
Thank you
You're welcome.
My answer is "three".
Offline radiolistener
  • Country: Earth
« Reply #8 on: February 25, 2024, 02:16:25 pm »
