Author Topic: Padauk programming  (Read 1190 times)
Offline Rob_of_KincardineTopic starter
Padauk programming
« on: March 11, 2021, 03:56:35 am »
Hello ALL
I just finished my first Padauk micro design and PCB layout, well almost.  I would like to add a few test pins on the PCB for programming. Then I would make a fixture that can be plugged into the programmer ZIF socket that has pogo pins to connect to my PCB.
The documentation for the programmer suggest only the F series (PFC multiple programming) can support in_circuit programming. If I use a PMS series and isolate pins PA3, PA5, PA6 would this work with my pogo pin adaptor board.  The schematic is attached, it's not easy to see but the 1uF cap and LED are isolated by solder jumpers.
Thanks for any suggestion or comments.
