Hello ALL
I just finished my first Padauk micro design and PCB layout, well almost. I would like to add a few test pins on the PCB for programming. Then I would make a fixture that can be plugged into the programmer ZIF socket that has pogo pins to connect to my PCB.
The documentation for the programmer suggest only the F series (PFC multiple programming) can support in_circuit programming. If I use a PMS series and isolate pins PA3, PA5, PA6 would this work with my pogo pin adaptor board. T
he schematic is attached, it's not easy to see but the 1uF cap and LED are isolated by solder jumpers.
Thanks for any suggestion or comments.
