Author Topic: PAL16R4B Programmer  (Read 3042 times)
Offline Mapleleaf107Topic starter
PAL16R4B Programmer
« on: January 14, 2020, 01:14:13 am »
A buddy of mine is refurbishing some old tech and needs to read and write to a PAL16RB4-2CN. I found some expensive programmers online for him but they are way over budget. Can anyone recommend an inexpensive programmer that could read/write this older PAL?
Offline up8051
Offline COREi64
Re: PAL16R4B Programmer
« Reply #2 on: January 14, 2020, 10:32:52 pm »
I'm the guy my buddy was talking about.
I have the original PAL chip only.  So, I'd need to be able to read the chip, then write it to a blank one.
Offline up8051
« Reply #3 on: January 15, 2020, 09:41:52 am »
So you need to find someone with appropriate programmer.
If the chip is protected you have to do reverse engineering.
I have labtool-48 but I far away from you.
Offline COREi64
« Reply #4 on: January 15, 2020, 02:08:22 pm »
The chip is not protected, so it's just a matter of finding (an affordable) programmer...  that's what I'm looking for, names/models of programmers I could look for.
Thanks
« Last Edit: January 15, 2020, 02:40:06 pm by COREi64 »
Offline up8051
« Reply #5 on: January 15, 2020, 04:16:09 pm »
Labtool-48
Labtool-48XP(UXP)
Dataman-48XP(UXP)
Xeltek Superpro-6100
Xeltek SuperPro-6104
Maybe look for the nearest technical university.
Offline COREi64
« Reply #6 on: January 15, 2020, 09:36:58 pm »
Thanks for the list, but I was thinking more in the neighborhood of 100+ dollars, not a 1000+.  These high end programmers negate the cost effectiveness of recreating the chip.
And unfortunately, I have no associations with universities.
Any lower priced options anyone?
I've heard the American Reliance AR9820 would do the job.  Having a tough time locating one.  Anyone here have one they don't need anymore?
« Last Edit: January 15, 2020, 09:49:23 pm by COREi64 »
Offline up8051
« Reply #7 on: January 15, 2020, 09:55:39 pm »
The problem with old PALs is that programming algorithm are not avaliable (even though chips are no longer produced).
You can find only some information in old ('90) databook.
Maybe it will be easier to reverse engineering it?
Do you have schematic of the device?
Is it a pinball or arcede game?
Offline COREi64
« Reply #8 on: January 16, 2020, 04:12:21 am »
The PAL is out of an old Commodore 64 accelerator cartridge called the TurboMaster CPU.  The chip in question is rather difficult to find and is required for an even more difficult to find "MasterAdapter" expander to function with it.  A friend has that chip and has determined that it can be duplicated.  I'd like to eventually duplicate it on my own (although he's offered to do it for me).
I've recreated the MA, and need to also include the PAL so that it can be utilized for all of it's available functions.
I have read about the process in which it could be reverse engineered, but that's sadly well beyond my capabilities at this time.  I'd love to be able to reverse engineer all four of the PALs on the accelerator board, but again... outside of my ability.
Finding an affordable way to duplicate the MA PAL is my immediate goal.
Offline up8051
« Reply #9 on: January 16, 2020, 09:56:52 am »
Is that device?
https://www.lyonlabs.org/commodore/hardware/index.html
First of all you should draw the shematic.
Maybe not all pins of PAL16R4 are used so reversing will be easier.
Eventually you can sent it to me, and I can try to read it in my Labtool
Offline up8051
« Reply #10 on: January 16, 2020, 12:53:13 pm »
Some discussion about the same:
https://www.lemon64.com/forum/viewtopic.php?t=64006&start=0
On page 3 you can find schematic.
Offline up8051
« Reply #11 on: January 19, 2020, 08:37:00 pm »
I found description of programming algorithm for OLD MMI PAL chips
« Last Edit: January 19, 2020, 08:38:52 pm by up8051 »
