Author Topic: RISC-V Summit 2019  (Read 3214 times)
Offline kfnightTopic starter
RISC-V Summit 2019
« on: December 04, 2019, 10:43:12 pm »
Who's going to be at the RISC-V Summit next week in Santa Clara?
Offline brucehoult
Re: RISC-V Summit 2019
« Reply #1 on: December 04, 2019, 11:20:43 pm »
Yup :-)
« Reply #2 on: December 05, 2019, 12:06:52 am »
That goes without saying.
Offline brucehoult
« Reply #3 on: December 05, 2019, 12:12:56 am »
Well, of course some of our top people will be there giving presentations, but not the entire staff :-)
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #4 on: December 05, 2019, 01:58:23 am »
Will the revolution be televised on the RISC-V YouTube channel?
« Reply #5 on: December 05, 2019, 04:06:23 pm »
Yes but it's usually a few weeks after the conference has concluded.
The following users thanked this post: I wanted a rude username
Offline [email protected]
  • Country: in
    • Linkedin Profile
« Reply #6 on: December 07, 2019, 05:04:39 pm »
Any new announcements expected?
I am looking forward to more advanced MCUs from there side.
Best Regards
Pallav Aggarwal
https://pallavaggarwal.in/my-story/
Offline brucehoult
« Reply #7 on: December 07, 2019, 07:54:17 pm »
No doubt  :-)
Some have already been made. See recent stories on https://www.reddit.com/r/RISCV/. There have been announcements from Think Silicon, De-RISC, Andes, IAR about things they will have on display at the Summit.
Who is "their"? The conference is run by the RISC-V Foundation, who don't do anything except publish the standards documents, test for compliance with them (not fully up and running yet), and organize working groups of delegates from the members to develop extensions to the standard. And organize conferences :-)
Actual hardware such as MCUs are design and made by the several hundred organizations that are members of the Foundation, just as actual chips containing ARM CPU cores are made by their 1500 or so licensees, not by ARM themselves.
https://riscv.org/members-at-a-glance/
In both cases, of course, some members or licensees are more active or more visible than others.
Offline brucehoult
« Reply #8 on: December 08, 2019, 12:11:41 am »
I'll note that Microchip are a founding platinum member and Espressif are a founding gold member of the RISC-V foundation, so I'd on general principles imagine they'll release products based on RISC-V sooner rather than later if they see some advantage to it. Replacing MIPS in PIC32 seems like an obvious thing. I imagine the ARM cores they got with Atmel are a lot safer.
I know people generally hold the peripherals and documentation of Microchip MCUs in high regard, so I expect that wouldn't change if they got a core-ectomy.
*This* year? No clue...
Offline donotdespisethesnake
  • Embedded stuff
« Reply #9 on: December 09, 2019, 10:03:42 pm »
Given Microchip's negative approach to Open Source, I guess the advantage for them will be to produce customised instruction sets so they can lock you into using their (non-free) compilers.
I expect there are other companies looking to do the same. It's ironic to use Open Source tools to create closed products, but there is already precedent for it even with GPL v2.
Bob
"All you said is just a bunch of opinions."
Offline brucehoult
« Reply #10 on: December 10, 2019, 12:35:06 am »
I can't see how that makes any sense.
First, adding a few custom instructions to a standard ISA doesn't prevent people from sticking to the standard instructions. It's also likely to be easy to add support for the custom instructions to the existing open gcc and llvm compilers, if they are actually vital to efficient programming. Or even simply create a small library of functions that use the inline assembler to create the custom instructions.
This is a completely different situation than using a completely custom ISA that is very different to anyone else's.
Second, I'm sure Microchip makes a heck of a lot more money from selling chips than they do from selling compilers, so it's to their advantage to make the compilers free or as cheap as possible. Maybe they feel they have to recover costs, and when they have their own weird ISA those costs are quite high. If they're using a standard ISA with standard compilers then their costs are much much lower.
« Reply #11 on: December 10, 2019, 02:11:15 am »
So it looks like, starting in 2020, the proceedings and materials of the RISC-V working groups will be made viewable to the public at large! Pretty kewl, and consistent with being an open source ISA.
