Author Topic: Scroll Up or Scroll Down?[SOLVED]  (Read 24616 times)
Online jpanhaltTopic starter
« on: February 25, 2023, 07:08:32 pm »
We all know that in Windows, when you want to look higher on the screen you move the scrollbar up.   That moves the screen down, right?
With an LCD when values are out of range high and the screen scrolls down to show them, is the button that can command that still a scroll up or scroll down button?
My adult daughter and "media expert" for her local school district says she would consider that scrolling down, i.e., the screen scrolls down to reveal higher values.  In our conversation today, we each succeeded in confusing each other.  She's a great sport and from my standpoint, it only means swapping two lines of code.
So, what's the definitive answer?  (BTW, I am not Faringdon in disguise.   :-DD )
EDIT: This is not unlike the difference between British and American manual lathes.  In the former, e.g., my 1960's Smart and Brown "infeed" and "outfeed" have the opposite meaning from American (e.g., Southbend and Hardinge) lathes.  You need to be stone sober when switching from one to the other.
« Last Edit: February 26, 2023, 09:13:08 am by jpanhalt »
Offline Benta
Re: Scroll Up or Scroll Down?
« Reply #1 on: February 25, 2023, 08:25:43 pm »
I have no 100% correct answer, but the convention is that "PgDn" or down arrow moves you down in the document. Now, this of course means that document moves up on the screen, but that's irrelevant. It's about your reading focus.
"PgUp" moves your focus backwards in the document.
The following users thanked this post: jpanhalt
« Reply #2 on: February 25, 2023, 08:36:00 pm »
Hi, Benta,
Thanks.  I know we both enjoy machining stuff.  You may not be familiar with the infeed vs. outfeed difference between older American and British lathes.  I believe Germain lathes follow the American convention.
John
Online SiliconWizard
« Reply #3 on: February 25, 2023, 10:12:22 pm »
There is no answer, but that's what is called "natural scrolling" or something, and has been an option at least in several Linux desktop environments for ages. Maybe MacOS too, although I'm not a user so, not sure.
So, nothing new, and a matter of personal preference. I do prefer the classic way. But if you prefer the inverse way, sometimes called "natural", why not. Both can be defended.
As long as we have a choice.
« Reply #4 on: February 25, 2023, 10:43:07 pm »
That's the whole problem.  My daughter pulls the screen down to see the top on her smartphone.  I don't have a smartphone.
I looked for a "standard" on Google, and all I came up with was the Windows (opposite) way.  Like I said, it is a trivial change in code, and I hadn't really thought much about it until I had my weekly telephone visit with that daughter.
I was wondering, since the EU and others have directives for toilet paper,* whether there was something relative to scrolling.
I'll wait a few more days to see whether the crowd here has some other view.
*So far I have not seen a directive for whether the loose end should be closest to the user or on the wall side.  That debate raged on Ann Landers years ago.
« Reply #5 on: February 26, 2023, 03:08:01 am »
A directive? |O
Are you guys after a nasty orwellian dictatorship or what? (As if it wasn't bad already as it is!)
That said, seems obvious that, while it may be down to personal preference, the most general approach is that "key up" for going up, "key down" for going down a document / a list of any kind, sounds like the most sane UI.
This has extended pretty naturally to the mouse wheel for a similar reason. Up is for going up, not for moving up a virtual page.
Now OTOH it also seems relatively obvious that touch interfaces are completely different, since you act on a touchscreen more as you would a sheet of paper. Thus the other way around.
One approach for each type of UI. Sounds like captain obvious to me, but apparently it's not for everyone.
And I don't get (in the sense that I absolutely dislike) the underlying idea of a single UI for all types of interfaces. We've had enough of that crap already with MS trying to force mobile touchscreen interfaces on the desktop. It doesn't work. Different interfaces, different UIs.
Offline ledtester
« Reply #6 on: February 26, 2023, 03:19:59 am »
For trackpads the behavior is usually customizable.
For touch screens the only option I've seen is the "natural" mode -- it's like your finger is physically moving the document.
For keypads (eg. arrow keys) it's like Benta said -- you are moving a cursor.
Online Whales
    • Halestrom
« Reply #7 on: February 26, 2023, 03:35:13 am »
Touch-worshippers and their desired direction of scrolling are the subcontractors of the devil sent here to slowly sue variations into the one true way.
I'm unusual in that I enable horizontal scrolling too.  Some software chokes (eg: in some image viewers even the tiniest amount of horizontal scrolling movement loads the next/prev image) but overall it's handy.  I presume folks who like vertical inverted also like this horiz inverted?
If you ever encounter someone using circular scrolling on their touchpad... murder first, ask questions later!
Re: Scroll Up or Scroll Down?[SOLVED]
« Reply #8 on: February 26, 2023, 09:11:45 am »
I've decided to use the Up Arrow for moving the screen down.  That is, the Windows  scroll convention which in my code equates to increasing an offset value.
As for directive, I meant that tongue in cheek.
Offline tooki
« Reply #9 on: February 26, 2023, 01:22:09 pm »
This issue is conceptually really simple: on computer displays, we have generally moved the viewport. So imagine the virtual, long document, and the viewport is a mask with a hole in it we can look through. When we scroll down (scroll wheel, page down key, etc) we are moving the mask down relative to the document.
In touchscreens, where the content tracks under your finger as you drag, the conceptual model is an unmoving viewport (mask), with the document moving beneath it. So you move it up to see what's farther down it.
In other words, it's akin to "are you moving the camera or the subject?"
Of course, mathematically these are simply the exact negatives of each other.
Offline Bicurico
  • Country: pt
  • Broadcast Systems & Transport Stream Analysis
    • VMA-Broadcast
« Reply #10 on: February 26, 2023, 02:12:57 pm »
It's the same with elevator buttons. Most people, to go up, press the down button, because it seems they are commanding the elevator to go down to where they are.
People are stupid.
Offline tooki
« Reply #11 on: February 26, 2023, 03:16:29 pm »
People are stupid.
"Most people"?? No.
I have literally never even heard of anyone making that mistake, never mind seen anyone make it. And even if we accept that some moron has thought that before, it's certainly not "most people". Everyone knows you press down to go down and up to go up.
You don't think about where the elevator already is right now -- and indeed, many elevators don't have an exterior display, so you can't know where it is.
Also, what would such people do or think when they're at the lowest or highest floor, and there is no button that would "command the elevator to go to where they are"??
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #12 on: February 26, 2023, 04:43:17 pm »
You are lucky to live in a country with smarter people. Come to Portugal and go to an official building, i.e. an hostpital. You will have lots of opportunities to see people "calling" the elevator to where they are, instead of just pressing the button of the direction they want to go to.
But mind you, it was just an example of how people understand and use a GUI in the exect opposite way it was intendend.
Regards,
Vitor
Offline Nominal Animal
« Reply #13 on: February 26, 2023, 04:45:29 pm »
Correct answer is, it depends: Do you have cats or dogs that like unrolling the paper?
If you do, then put the loose end closest to the wall.  While the paper can still be unrolled, it is less easy for anyone without opposable fingers.
Otherwise, put the loose end furthest from the wall, so that pulling downwards and yanking downwards and slightly towards the wall and sideways will separate a section at a perforation, because such a yank increases the friction against the wall enough.
In the loose-end-closest-to-wall case, you usually need another hand or other limb to push the roll to the wall, or otherwise stop rotating, to have a piece separate along the perforations.  A trick is to pull the paper upwards and towards the wall, then yank slightly sideways to separate along a perforation, as it behaves the same as the other way downwards.  The downside is that you'll leave a longer than necessary "tail" hanging off the roll.
As to scroll, my preference using a touchpad is opposite to my preference using a touchscreen.  Try and take that choice away from me and I'll bite you.
« Last Edit: February 26, 2023, 04:49:33 pm by Nominal Animal »
« Reply #14 on: February 26, 2023, 07:20:33 pm »
Again, while a convention, this one looks like the most sensible if you're interacting with *keys*. Up is rather naturally "going up" in a list or document.
Touchscreen interfaces appear to implement it the other way around, but *only* for swiping the screen with your fingers. If you swipe downwards, you'll naturally expect the screen's content to move downwards. It's a completely different interaction, and that's fine.
Insisting on "swiping" here, because if you implement virtual buttons on a touchscreen, like "up" and "down" buttons, the "key" convention makes a lot more sense. So it's not just about touchscreen UIs or not, but about swiping or nor swiping.
To swipe or not to swipe... :horse:
Sure people used, almost exclusively, to mobile, touchscreen interfaces may find using a desktop-like UI, or even any device with just buttons, difficult, and being exposed mainly to one type of interface tends to make them want to use it for everything. That's human.
Of course, the "toilet paper" thing made that obvious, but it still looked like something that could very well happen - wouldn't be too surprised - so, the idea made me cringe. :-DD
Brave new world...
Offline tooki
« Reply #15 on: February 27, 2023, 09:10:06 am »
Heh. That reminds me of the last cat I had. When he was a kitten, he unrolled the toilet paper once. It was just too cute to even try and stop him. He was laying on his back, claws in the air, in an ever-growing pile of tissue. This was before phones did video, so no evidence of it. But he only ever did it the one time, never again!
We just used toilet paper off the floor for a week. 😂
The following users thanked this post: newbrain, Nominal Animal
« Reply #16 on: February 27, 2023, 10:51:14 am »
Update
I gave my roast monitor its third test yesterday with a pork loin roast (more about that to come in "cooking").  It's still very "beta" in development and my skills with a new camera (Nikon Z30) are primitive -- all the images are too dark and have a blue streak color aberration.
The LCD monitor scrolls automatically when data are received that are out of limits high, low, or time (screen only goes to 60 minutes).  The two images attached show a command scroll.  The camera is sold as "vlogging" enhanced, but I haven't figured out how to do a movie yet.  Scroll is just a very quick blink.  There is no perceptible redrawing.  MCU is a PIC16F1789 at 16 MHz.
Offline mikerj
« Reply #17 on: February 27, 2023, 12:16:21 pm »
People are stupid.
"Most people"?? No.
FWIW I have absolutely seen people do this.  I don't think most people do it, but I would expect it is a significant minority.
« Reply #18 on: February 27, 2023, 01:16:08 pm »
People are stupid.
"Most people"?? No.
FWIW, I've seen people eat yellow snow, and walk into a lightpost and a decorative pool while staring at their cellphones.  There is no limit to human willful ignorance/stupidity: having the capability to understand and behave rationally, but simply choosing not to.
I can understand people having been lied to by friends or even family members, but the concept of "press the button to tell the lift which way you want to go, up or down", should be quite idiot-proof enough.  Labels like "don't dry your cat in the microwave" are not helpful, they're annoying and ridiculous.  I'd much rather live in a world that catered to rational people, than in one which tries to coddle the lowest possible common denominator.  Let natural selection do its job, I say.
Offline shapirus
  • Country: ua
« Reply #19 on: February 27, 2023, 02:11:02 pm »
If typewriters still were a thing, someone would definitely invent one that had line feed moving upwards to print the new line above the one printed before it, and call it an innovation, a "natural" text flow direction or whatever the marketing BS term of the day would be.
Offline tooki
« Reply #20 on: March 06, 2023, 02:35:26 pm »
Marketing had nothing to do with the changes in UI design.   :palm:
Offline shapirus
  • Country: ua
« Reply #21 on: March 06, 2023, 03:47:46 pm »
maybe. whatever/whoever the "think different" BS is pushed by just for the sake of being different with no practical justification.
Offline james_s
« Reply #22 on: March 06, 2023, 06:44:38 pm »
People are stupid.
They do? I've never done that or noticed somebody else doing it, but I can't say it has ever occurred to me to pay attention.
Not really an issue at the building I work in now, you tap the floor you want to go to on the touchscreen in the hall and then get on the elevator that arrives to take you there. It's kind of silly though in that there are no buttons inside the elevator car itself so I often see people follow someone else into whatever car opens up and then the door closes and they realize they can't select a floor and have to ride to wherever it's going, get off and then select the floor they want in that hall.
Offline artag
« Reply #23 on: March 06, 2023, 08:58:47 pm »
Sounds like a UI invented by a lift engineer rather than a user  (ie thinks about the mechanism, and the optimal strategy not the operation).
What happens if two people are waiting for lifts and the first lift arrives. Which of them should board it ?
Offline artag
« Reply #24 on: March 06, 2023, 09:09:50 pm »
I think Windows and Linux do it the same, since I was confused by Macs doing it 'wrong' when I first encountered one. I quickly found there was an option to reverse it. I guess that's the best way - let the user choose. But that's more appropriate to a full-blown GUI than a touchscreen panel.
An then there are those differential-speed web scrolling interfaces, whose only point seems to be to attract attention to the cool interface rather than be intuitive. Intellectual masturbation.
