Author Topic: Starting with STM32 (NUCLEO-L412KB)  (Read 10882 times)
Online PicuinoTopic starter
    • Picuino web
« on: April 29, 2024, 06:40:01 pm »
I have purchased a NUCLEO-L412KB board with a STM32L412KBU6 microcontroller.
After installing the IDE (STM32CubeIDE 1.3.0) I don't know where to start to do something as simple as turning on a led.
Is there any way to load a sample project to work with?
This is the page of the product in st.com: https://www.st.com/en/evaluation-tools/nucleo-l412kb.html
Product data brief: https://www.st.com/resource/en/data_brief/nucleo-l412kb.pdf
« Last Edit: May 24, 2024, 12:06:00 pm by Picuino »
Offline coromonadalix
Re: Starting with STM32 (NUCLEO-L412KB)
« Reply #1 on: April 29, 2024, 06:51:41 pm »
you could start with arduino v2.xx and install all stm32 librairies / boards ...   download and install "stm32programmer"  ,  not the same as stm32 cube
when you have all ready, com port and port type selected ....    you can use arduino examples on stm32  without problems
i use nucleo L432KC and nucleo144-F412ZG boards like this ...
you use the integrated st-link  of the nucleo boards for the programming interface
« Last Edit: April 29, 2024, 06:53:16 pm by coromonadalix »
The following users thanked this post: Picuino
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #2 on: April 29, 2024, 06:52:56 pm »
For a family like STM32L4xx they have a repository with HAL drivers and that repository includes lots of sample projects. For me the repository got installed when using CubeMX to create a new project. I mean in CubeMX you can select the board you have to create a new project for that board. Then the proper repository will be downloaded and installed on the local computer. After that you can select one of the sample projects.
I don't use their IDE but EWARM. Probably you can invoke CubeMX from inside the IDE.
Regards, Dieter
    • Picuino web
« Reply #3 on: April 29, 2024, 07:53:00 pm »
When uploading the program to the board it asks me for the file STM32_Programmer_CLI.exe
    • Picuino web
« Reply #4 on: April 29, 2024, 08:02:08 pm »
I have added to the PATH the path where the application STM32_Programmer_CLI.exe was located and now it does not give the previous error.
Now it gives this error:
Sketch uses 13016 bytes (2%) of program storage space. Maximum is 524288 bytes.
Global variables use 1300 bytes (0%) of dynamic memory, leaving 162540 bytes for local variables. Maximum is 163840 bytes.
                       STM32CubeProgrammer v2.16.0
ST-LINK SN  : 066AFF575056716587092913
ST-LINK FW  : V2J36M26
Board       : NUCLEO-L412KB
Voltage     : 3.26V
SWD freq    : 4000 KHz
Connect mode: Under Reset
Reset mode  : Hardware reset
Error: Unable to list supported devices
Error: Cannot identify the device
Failed uploading: uploading error: exit status 1
« Last Edit: April 29, 2024, 08:06:32 pm by Picuino »
    • Picuino web
« Reply #5 on: April 30, 2024, 03:29:46 pm »
I don't understand how it can be so complicated to just plug in a simple development board.
I have tried it with Arduino and it gives me error.
I have installed all the ST tools in the latest version (STMCubeMX, STMCubeIDE, STMProgrammer and libraries for NUCLEO-L412KB) and it doesn't work either.
The error that STMCube gives me is attached:
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #6 on: April 30, 2024, 03:41:37 pm »
The board includes a STLink USB debugger. Is that device enumerated when you plug it into your workstation? I remember downloading and installing a driver for that.
After enumeration there are three USB interfaces:
the STLink debugger "STMicroelectronics STLink dongle",
a CDC serial device "STMicroelectronics Virtual COM Port (COMnn)" and
a memory device with two files on it (DETAILS.TXT and MBED.HTM)
Regards, Dieter
Offline pcprogrammer
« Reply #7 on: April 30, 2024, 03:48:12 pm »
You can also try with openocd. Don't know about the availability and how to use it under Windows, but on Linux I find it quite easy.
Under Linux there is no need for a driver to use the ST-link, but there is the need for setting an udev rule for it to be able to use it. For openocd a target file is needed which you can most likely find on line or setup your self based on other examples.
    • Picuino web
« Reply #8 on: April 30, 2024, 04:00:09 pm »
Regards, Dieter
I'm working in Windows 10.
* I can see the memory device with two files on it.
* The port com6 is linked to the board. Arduino debug and STM32CubeProgrammer recognize the microprocessor and the board without problems.
* In the device manager I can see ST-Link Debug
Perhaps is a problem with the project example for the board. I have selected the board well (I have checked it several times), but perhaps the example project is missing something.
Regards.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #9 on: April 30, 2024, 04:27:55 pm »
As far as i know the cube IDE is based on eclipse and with eclipse i remember that one needs to configure the make and run steps. If it doesn't work automatically, maybe because you loaded source files instead of the project file. The project file should provide the required configuration. There should be a choice of "Release" and "Debug", at least that's what i have in EWARM.
Regards, Dieter
    • Picuino web
« Reply #10 on: April 30, 2024, 04:46:00 pm »
I think I had opened it as File instead of as Project.
Now it does not give error.
The problem now is that the program bypasses Avast's antivirus shield.
It says that ST-LINK_gdbserver.exe is infected with IDP.Generic.
    • Picuino web
« Reply #11 on: April 30, 2024, 04:55:50 pm »
Could be a false positive.
I have scanned the file on the virustotal.com website and it does not give any infection results.
    • Picuino web
« Reply #12 on: April 30, 2024, 04:59:03 pm »
Ok it is running in debug mode.
Thank you very much.
Offline Sacodepatatas
« Reply #13 on: April 30, 2024, 05:51:49 pm »
Avast's heuristics thinks there is something wrong with the file because the program, in order to access to the debug probe, performs external calls to a DLL that is located elsewere from where they use to be (anywhere in the path variable, current directory, or system path), because such path to the DLL is passed as command line parameter from the IDE.
Offline eugene
« Reply #14 on: May 01, 2024, 05:28:32 pm »
The STM32 MOOCs are a pretty good place to start. Have you seen them?
https://www.st.com/content/st_com/en/support/learning/stm32-education/stm32-moocs.html
90% of quoted statistics are fictional
The following users thanked this post: dietert1, tellurium
    • Picuino web
« Reply #15 on: May 01, 2024, 08:00:13 pm »
I did not know them. Thank you very much.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #16 on: May 02, 2024, 04:05:13 pm »
Another nice learning series is "FreeRTOS TUTORIALS" on youtube by ControllersTech. They show it using CubeIDE.
Regards, Dieter
« Reply #17 on: May 03, 2024, 04:42:08 pm »
for the STM32_Programmer_CLI.exe error
You have to install them to their default locations,  and for Arduino IDE,  i use the full install,  not the portable one
took me hours to figure this out,   no help from ST nor Arduino   |O |O
Once you select the right board type, programming interface, com port ...  and once you install the libraries related to some projects,  mostly the FreeRTOS  ...  Timer ...
    • Picuino web
« Reply #18 on: May 13, 2024, 06:00:53 pm »
I have not been able to turn the LD3 led back on again. I don't know what I am doing wrong. The project compiles without errors and downloads to the board. A few days ago I managed to turn on the led, so the board is fine, but now I have not managed to do it again.
The project is generated with CubeMX and modified the main.c so that the led turns on and off, but it doesn't work.
I attach the main.c program:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
     HAL_GPIO_WritePin(LD3_GPIO_Port, LD3_Pin, GPIO_PIN_SET);
     HAL_Delay(100);
     HAL_GPIO_WritePin(LD3_GPIO_Port, LD3_Pin, GPIO_PIN_RESET);
     HAL_Delay(100);
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    Error_Handler();
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 20;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    Error_Handler();
  * @brief USART2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_1, GPIO_PIN_RESET);
  /*Configure GPIO pin : PA1 */
  GPIO_InitStruct.Pin = GPIO_PIN_1;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /*Configure GPIO pin : LD3_Pin */
  GPIO_InitStruct.Pin = LD3_Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(LD3_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
EDIT:
This is my code:
  while (1)
     HAL_Delay(100);
     HAL_Delay(100);
« Last Edit: May 13, 2024, 06:12:38 pm by Picuino »
Offline 8goran8
  • Country: cs
« Reply #19 on: May 14, 2024, 07:11:47 am »
Just increase the value for HAL_Delay.
Try with HAL_Delay(1000);
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #20 on: May 14, 2024, 07:33:09 am »
Also i would recommend to keep those
/* USER CODE BEGIN .. */
/* USER CODE END .. */
blocks created by CubeMX intact and use them properly in order to not lose my code the next time CubeMX regenerates the project.
Last week i wrote a lot of code for a STM32L432 and found it nice to work with. I used C++ and didn't have to think about RAM or Flash limits - somewhat unusual when working with a MCU. Although it has a single precision FPU i used lots of doubles.
Regards, Dieter
    • Picuino web
« Reply #21 on: May 14, 2024, 07:53:36 am »
Yes, it is quite a powerful microcontroller in many ways. Much more than any of the ones I've used so far, including the 16bit ones.
I've had the STM32 board in a drawer for quite some time and I've finally decided to use it.
The problem is that, for some reason, it's hard for me to start something as simple as the "hello world" of microcontrollers (blinking led).
EDIT:
When I change the pin to a different pin, it remains as an input and not as an output. Of course the output voltage value does not change either.
« Last Edit: May 14, 2024, 08:03:24 am by Picuino »
    • Picuino web
« Reply #22 on: May 14, 2024, 01:49:09 pm »
I have no idea what the problem was.
I have reinstalled all the IDE programs again and now it works fine. Finally I have the led blinking.
    • Picuino web
« Reply #23 on: May 14, 2024, 03:34:32 pm »
I am testing turning a digital output on and off. The program I am using is as follows.
while (0) {
   HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_SET);
   HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_RESET);
On the oscilloscope I get a 470kHz square signal, which seems to me too slow for an 80MHz microcontroller.
Is there any way to write directly to the registers to turn on and off a digital output?
    • Picuino web
« Reply #24 on: May 14, 2024, 03:42:54 pm »
I answer myself:
while (1) {
       GPIOA->BSRR |= (1<<3);  // Set PA3 (Pin A2 in the Nucleo board)
       GPIOA->BSRR |= (1<<(3+16));  // Reset PA3
1880kHz output (200ns High and 300ns Low)
I think the clock is set too slow.
EDIT:
After configuring the internal clock to 80MHz, the output doesn't work.
That was the mistake I had. I don't know how to set the clock properly with the external oscillator.
« Last Edit: May 14, 2024, 03:48:27 pm by Picuino »
