Well, it's a question of market. But also die size. 8-bit MCUs take up much less die area for the logic part, but is that necessarily always a benefit? For the older/larger node sizes, sure. But if you wanna use any more recent and finer node size, then an 8-bitter becomes rapidly pad-limited, meaning that unless it has very, very few IOs, or you have like a multi-core chip with a number of cores (but I haven't seen vendors taking this path really), then a given die would essentially be empty, most of the area being defined by the pads. Which is pretty wasteful. So 8-bitters have become kinda niche - partly because they have lower performance, but even if the performance is adequate for some applications, then you have this factor that you become essentially stuck with older process nodes, or the chip becomes absolutely not competitive cost-wise.
