Author Topic: Tiny 2040  (Read 8803 times)
Offline iMoTopic starter
  • Country: nr
Tiny 2040
« on: March 12, 2021, 09:28:35 pm »
Interesting stamp:
Online tszaboo
Re: Tiny 2040
« Reply #1 on: March 12, 2021, 10:04:21 pm »
Hey look, something that does less things for more money.
Measure power rails with 2GHz bandwidt: https://eleshop.eu/prp1-power-rail-probe.html
The following users thanked this post: Bassman59, newbrain
Offline SiliconWizard
Re: Tiny 2040
« Reply #2 on: March 12, 2021, 11:14:34 pm »
It's tiny.
I have a product idea, a small stamp based on a NXP i.MX RT1170 with only 1 GPIO. Can you beat that!
Offline RoGeorge
Re: Tiny 2040
« Reply #3 on: March 12, 2021, 11:21:58 pm »
Why USB-C and not mini or micro USB?
Offline oliviasmithh900
Re: Tiny 2040
« Reply #4 on: March 13, 2021, 11:14:25 pm »
Now everything's shifting to USB-C for better speed (I guess) and the main benefit is you can plug it in both ways  :=\
Offline Nominal Animal
Re: Tiny 2040
« Reply #5 on: March 14, 2021, 09:11:45 am »
The connector does not affect the speed at all.  2040 is only capable of USB LS (low speed, 1.5 Mbits/s) and FS (full speed, 12 Mbits/s), regardless of the connector used.
Offline NorthGuy
Re: Tiny 2040
« Reply #6 on: March 14, 2021, 02:05:41 pm »
USB type C connector is much better - easier to plug in, comes in both ways, has much better holding power.
Offline mattselectronics
    • Matt's Electronics
Re: Tiny 2040
« Reply #7 on: March 15, 2021, 03:18:09 pm »
Most USB-C Ports are also mechanically much more robust than all the other small USB connectors. This alone lets me preferr it over mini or micro USB connectors.
Offline DavidAlfa
Re: Tiny 2040
« Reply #8 on: March 15, 2021, 03:37:25 pm »
Mini and micro USB connectors love to break.
I didn't feel sorry for them when the USB C came into the game :-+
Re: Tiny 2040
« Reply #9 on: March 15, 2021, 05:32:05 pm »
None of my devices have USB C connectors, and I don't even have a USB C cable yet, so I cannot comment on whether the C connector is better.
I hope so; but just don't know for sure yet, personally.
Re: Tiny 2040
« Reply #10 on: March 15, 2021, 05:36:34 pm »
It is definitely much better.
Drawback for the designer is that they are much more annoying to route (I mean, if you want to route them properly.) Another one is that they are hard to solder without a reflow oven. Unless you go for a mid-mount, with mixed SMD and TH pins. I've designed a couple boards with such a connector, and they are solderable by hand with no issue. And, another drawback is that they are a bit more expensive.
The fun side with this tiny board is that the connector is almost half the size of the board itself.
The following users thanked this post: Nominal Animal
Offline NorthGuy
Re: Tiny 2040
« Reply #11 on: March 15, 2021, 07:23:10 pm »
The type C connectors for USB 2.0 are very simple - single line, 0.5mm pitch. You do need two resistors, but these are needed only if the other end of the cable is connected to real type C port. If the other end is type A then resistors are not used.
The type C connector for USB 3.0 is a bitch. The ones with two rows of SMD contacts are difficult to route and I guess you won't get a good yield with them. The ones with pins for the back side are much better though - easier to route, and easier to solder, and IMHO are better from SI viewpoint. I made a board with them. It worked, but I'm still working on a decent footprint for the next version - you need very small holes very close together. Also, they actually require a mux which switches the wires depending on the orientation of the plug - that's another $1-2 to your cost.
For the Pico board, which is USB 2.0 (actually FS only), the USB 3.0 entanglements don't matter. I would use type C without any doubts. The micro B connector is not much smaller and is not nearly as nice as type C.
Re: Tiny 2040
« Reply #12 on: March 15, 2021, 09:52:20 pm »
Do you have an recommondation for a USB 2.0 type C connector?
Is there any defacto standard on a footprint, that is used by multiple manufacturers?
So far I only found connectors with different footprints and that sucks, if that specific part is out of stock.
The following users thanked this post: Tagli
Offline RoGeorge
Re: Tiny 2040
« Reply #13 on: March 15, 2021, 10:59:41 pm »
Same here!
- Just when I was starting to have plenty of USB type B cables, everybody started to use USB type B mini.  Not nice, but OK.  Challenge accepted.   :box:
- Then, gathered in time enough USB type B mini cables.  That was when USB type B micro started to be the new mini.  That was quite a lame move.  Very fragile and hard to fit connector and, of course, new cables.   >:(
- But hey, that's progress.  For the 3rd time, piled up a reasonable number of cables, this time of USB type B micro.   ::)
And now, USB type C !?   ???
Offline NorthGuy
Re: Tiny 2040
« Reply #14 on: March 16, 2021, 01:01:03 am »
IMHO, the most common footprint (not the exact part, but the footprint) is this:
https://www.digikey.com/en/products/detail/gct/USB4105-GF-A/11198441
Offline lucazader
Re: Tiny 2040
« Reply #15 on: March 16, 2021, 02:18:03 am »
Can confirm with Northguy.
That is the most common one to find.
Can be had with reasonable quality in china for around $0.1 (USD) or less each.
Offline mikerj
Re: Tiny 2040
« Reply #16 on: March 16, 2021, 09:40:15 am »
Same here!
The mini connector was the worst of all of them in terms of reliability, the micro was far better in terms of insertion life.
Re: Tiny 2040
« Reply #17 on: March 16, 2021, 05:59:46 pm »
Yeah. Even for pure USB 2.0, you still need to route both sides for the differential pair, which is reversed, so that's still a bit annoying. Requires tiny vias and proper symmetry. That is, if you want to route it properly, as I mentioned.
Offline NorthGuy
Re: Tiny 2040
« Reply #18 on: March 16, 2021, 08:38:08 pm »
Not that annoying:
Online tszaboo
Re: Tiny 2040
« Reply #19 on: March 16, 2021, 10:47:59 pm »
Not that annoying:
Yes, but reflections. Imbalance. OCD. Differential pair routing.
Mostly OCD. It doesn't look right. It feels wrong.
Oh, and the power has to come out of the port below those 5.1K resistors. Bad.
« Last Edit: March 16, 2021, 10:51:28 pm by NANDBlog »
Re: Tiny 2040
« Reply #20 on: March 16, 2021, 10:57:59 pm »
Not that annoying:
Besides those points - that may not be a big problem for USB HS - you can't route that way will all connectors. The only ones that I've found hand-solderable had pins that were not laid out like this, and which pretty much required using vias. Now I'd be interested in connectors that are both easy to route and easy to solder, but I couldn't really find any (at least available) when I needed them.
Online tszaboo
Re: Tiny 2040
« Reply #21 on: March 16, 2021, 11:15:15 pm »
Not that annoying:
After banging my head for a long time, I settled on a connector that only has 12 pins. It looks like it has more, but actually there are pins shorted together, or way to close to each other. I've found TYPE-C-31-M-12 which is a LCSC part, and a compatible one from Digikey (not sure about the part number). I haven't tried soldering it yet.
But to just brag a bit, I've soldered 1x2mm TVS arrays with 15 pins, DDR2 memory with hot air and this one doesn't look that difficult.
Offline DavidAlfa
Re: Tiny 2040
« Reply #22 on: March 16, 2021, 11:37:00 pm »
What's the drama with the vias?
Are you doing single side boards yourself and soldering 0.5-0.3mm pitch components?
Without solder mask it's impossible. It will cause shorts everywhere.
The pair requires length matching if there's a considerable track length in the board.
Otherwise, mounting it as close as possible to the interface, for 20... 50mm... will work well.
I know it will break some ethics, buts that's true :D
I used a vertical, 90° angle, tru-hole connector in a personal project 2 years ago. Not a big deal, but 0.3mm vías and 6mil traces were needed.
The space was a problem, that connector solved it very nicely.
« Last Edit: March 16, 2021, 11:45:05 pm by DavidAlfa »
Offline NorthGuy
Re: Tiny 2040
« Reply #23 on: March 17, 2021, 01:02:42 am »
Look at the DigiKey link I posted few posts ago. This footprint is very common. There are many parts with this footprint. They're very easy to route. They're very easy to solder manually. I soldered a dozen of test boards manually to test the enclosure fit.
Re: Tiny 2040
« Reply #24 on: March 17, 2021, 05:56:08 pm »
Thanks. The one on your link is 0 stock. I think similar connectors were also hard to order, back when I needed them, at least from the distributors I use. But I'll certainly keep an eye on this for next time.
