Author Topic: Tiny 2040  (Read 8581 times)
Online tszaboo
Re: Tiny 2040
« Reply #25 on: March 17, 2021, 06:06:34 pm »
The only ones that I've found hand-solderable had pins that were not laid out like this, and which pretty much required using vias. Now I'd be interested in connectors that are both easy to route and easy to solder, but I couldn't really find any (at least available) when I needed them.
Look at the DigiKey link I posted few posts ago. This footprint is very common. There are many parts with this footprint. They're very easy to route. They're very easy to solder manually. I soldered a dozen of test boards manually to test the enclosure fit.
Thanks. The one on your link is 0 stock. I think similar connectors were also hard to order, back when I needed them, at least from the distributors I use. But I'll certainly keep an eye on this for next time.
Actually, Digikey's site is broken. If you search for the connector, they say they have more than 5000 on stock. You click on it, and it's 0. Farce.
https://www.digikey.com/en/products/filter/usb-dvi-hdmi-connectors/312?s=N4IgjCBcoEwBxVAYygMwIYBsDOBTANCAPZQDaIALGHAMwCcArCALqEAOALlCAMocBOASwB2AcxABfQgFoE0ECkgYcBYmRAwADAHYaLCQaA
Measure power rails with 2GHz bandwidt: https://eleshop.eu/prp1-power-rail-probe.html
