Author Topic: Using Atmel SAM Devices  (Read 10565 times)
Offline BocaDevTopic starter
« on: September 22, 2018, 06:42:54 pm »
I have a few basic questions about Atmel SAM devices.
Is it better to work with ASF and forget the GUI interface START? Or perhaps is it the other way around?
Also is it possible to switch between one and the other during development? I'm not finding a way to do it, but I may not be doing something correctly.
For example, I'm working on the SAMC21 and I find that setting the clocks in START to be pretty straight forward and all the oscillators combinations have been working as expected. I finally settled on using the external 32KHz oscillator running as the ref. into the PLL running at 24MHz. Works great!
Then I moved onto the START ADC (async) example and found the EOC interrupt function was completely empty for retrieving conversion results. Not very helpful. I even found a post on the Atmel community board about this problem, but after 4 years since that post, the START ADC example has never been corrected. Is this a common problem with START. It would be nice if they had a link on each configuration page to report errors. What is the best way to report START page errors?
So I then thought I would try my hand at using ASF. After several days of kicking the dog in frustration, I found it to be very convoluted.
Is it me or are other Atmel SAM sport-fans users having the same experience? So what's the best way to get these devices setup and running so one can get on with the programming in hand? I'm beginning to think the best path is to program these chips during startup is at the register level (OMG).
Thank you for any inputs and suggestions. :)
Offline ataradov
    • Personal site
Re: Using Atmel SAM Devices
« Reply #1 on: September 22, 2018, 08:07:24 pm »
What to use is a matter of personal preference.  You already studied both frameworks to a certain extent - pick the one you like more. There are incremental changes and bug fixes over time, but don't just sit and expect one or the other will get much better over time.
It is impossible to switch sides mid-development. You have to pick one or the other.
Start is probably a better way to go long term, since even now there is no ASF port for some newer devices.
It is not hard at all to use the device on a register level, and that's what I personally do. I have a number of simple starter project that you can use here https://github.com/ataradov/mcu-starter-projects
Alex
« Reply #2 on: September 22, 2018, 11:06:17 pm »
Thanks ataradov,
I'll go look into your starter project. Probably just what I need to get beyond the chip setup phase of development. :)
Offline ataradov
    • Personal site
« Reply #3 on: September 22, 2018, 11:10:19 pm »
There are also lots of other projects there that use Atmel SAM parts. There is probably nothing for C21 specifically, since I have not used this part a lot, but all devices are very close in spirit can the code is reasonably easy to port.
 I also have lots of scattered samples for various peripherals, but they are not published anywhere. But if you get stuck on something - just ask, I may have an answer.
Alex
« Reply #4 on: September 24, 2018, 03:15:03 pm »
ataradov,
Where I am coming to a stop is trying to get the ADC to work in async. I configured it using START however I see nothing within the results register when I have a breakpoint on the callback. Results register is zero.
Is there any other working examples available for using the ADC in async that I may use as a guide? Hopefully without START or ASF.
Thanks
Offline ataradov
    • Personal site
« Reply #5 on: September 24, 2018, 04:10:27 pm »
Here is an example. I re-wrote it to be asynchronous from a synchronous implementation without testing, but it should work. This example assumes that you initiate every single conversion. If you want a free-running mode, then you will have to set FREERUN bit and initiate the first conversion in the adc_init() function.
Let me know if this does not work and I will test it.
HAL_GPIO_PIN(ADC,      A, 2)
void adc_init(void)
  HAL_GPIO_ADC_in();
  HAL_GPIO_ADC_pmuxen(HAL_GPIO_PMUX_B);
  MCLK->APBCMASK.reg |= MCLK_APBCMASK_ADC0;
  GCLK->PCHCTRL[ADC0_GCLK_ID].reg = GCLK_PCHCTRL_GEN(0) | GCLK_PCHCTRL_CHEN;
  while (0 == (GCLK->PCHCTRL[ADC0_GCLK_ID].reg & GCLK_PCHCTRL_CHEN));
  ADC0->CTRLA.reg = ADC_CTRLA_SWRST;
  while (ADC0->CTRLA.reg & ADC_CTRLA_SWRST);
  ADC0->REFCTRL.reg = ADC_REFCTRL_REFSEL_INTVCC2 | ADC_REFCTRL_REFCOMP;
  ADC0->CTRLB.reg = ADC_CTRLB_PRESCALER_DIV32;
  ADC0->CTRLC.reg = ADC_CTRLC_RESSEL_16BIT;
  ADC0->AVGCTRL.reg = ADC_AVGCTRL_SAMPLENUM_128;
  ADC0->INPUTCTRL.reg = ADC_INPUTCTRL_MUXPOS_AIN0 | ADC_INPUTCTRL_MUXNEG(0x18/*GND*/);
//  ADC0->CALIB.reg = ADC_CALIB_BIAS_CAL(NVM_READ_CAL(ADC_BIASCAL)) |
//      ADC_CALIB_LINEARITY_CAL(NVM_READ_CAL(ADC_LINEARITY));
  ADC0->INTENSET.reg = ADC_INTENSET_RESRDY;
  NVIC_EnableIRQ(ADC0_IRQn);
  ADC0->CTRLA.reg = ADC_CTRLA_ENABLE;
int adc_read(void)
  ADC0->SWTRIG.reg = ADC_SWTRIG_START;
void irq_handler_adc0(void)
  int data = ADC0->RESULT.reg;
  // TODO: use data
Alex
« Reply #6 on: September 24, 2018, 06:32:16 pm »
Thanks ataradov, I will give this a try today or tomorrow and let you know how I made out.
Alan
« Reply #7 on: September 24, 2018, 07:49:47 pm »
ataradov
I added the ADC example you provided and I am not having any results. My program is:
#include <stdlib.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include "samc21.h"
#include "hal_gpio.h"
#define _nop() asm("nop")
#define F_CPU 24000000
HAL_GPIO_PIN(LED,      A, 15)
HAL_GPIO_PIN(BUTTON,   A, 28)
HAL_GPIO_PIN(UART_TX,  A, 22)
HAL_GPIO_PIN(UART_RX,  A, 23)
void adc_init(void)
HAL_GPIO_ADC_in();
void adc_read(void)
// TODO: use data
static void sys_int(void)
// Set flash wait states to maximum for 24 MHz operation
NVMCTRL->CTRLB.reg = NVMCTRL_CTRLB_RWS(1) | NVMCTRL_CTRLB_MANW;
// Switch to 48MHz clock and divide by 2
OSCCTRL->OSC48MDIV.reg = OSCCTRL_OSC48MDIV_DIV(1);
int main(void)
sys_int();
adc_init();
adc_read();
while(1)
I'm not receiving any interrupts. Should I have added a NVIC_EnableIRQ(ADC0_IRQn); at the end of adc_init?
Offline ataradov
    • Personal site
« Reply #8 on: September 24, 2018, 08:07:52 pm »
You never call adc_read() in your code.
Also, what startup files you are using? Mine or from ASF? The IRQ handler function name must match the one in the vector table.
EDIT: I see that you do call adc_read(), missed it. Let me create a complete test project.
« Last Edit: September 24, 2018, 10:26:14 pm by ataradov »
Alex
Offline matseng
    • My Github
« Reply #9 on: September 24, 2018, 10:24:14 pm »
I just want to say that thanks to Ataradovs SAM project collection at GitHub I could ignore both ASF and Start and do it the "proper" register-way instead.
 Well... Almost, I use the hal_gpio macros, but that's only half-cheating and actually make the code more readable.
Offline ataradov
    • Personal site
« Reply #10 on: September 24, 2018, 10:38:07 pm »
Here is a complete example that uses ADC with interrupts and prints the results on a serial port. This was tested on a real board and works for me.
Alex
« Reply #11 on: September 25, 2018, 06:31:08 pm »
Hi ataradov,
I am having issues with setting breakpoints in main.c. In fact, I can not even start debugging and break at main. I can run the program and see the LED flashing and pressing the button causing the blink rate to change, but I am unable to set any breakpoints.
Do I have something setup wrong?
Offline ataradov
    • Personal site
« Reply #12 on: September 25, 2018, 06:33:53 pm »
Go into the project settings and under the compiler tab check that debugging level is set to maximum.
« Last Edit: September 25, 2018, 06:37:19 pm by ataradov »
Alex
« Reply #13 on: September 25, 2018, 06:59:38 pm »
That did it. It was set for none which explains the problem. Never had that issue before but I now know to look for this.
Thanks,
Alan
« Reply #14 on: September 25, 2018, 07:30:07 pm »
Hi Alex,
I see your first name is Alex and that you live in the silicon valley area, you should be working for Atmel in offering help to their customers.
I imported your main program having the ADC code and a print out added as a bonus! It is just working fine and I really appreciate all the help you have provided me. :D
I should be good now and able to get on with my main task, with the help of following your examples.
Thanks again,
Alan
Offline ataradov
    • Personal site
« Reply #15 on: September 25, 2018, 07:59:18 pm »
I do. It says this much on my site linked from my profile here :)
Alex
« Reply #16 on: September 25, 2018, 08:19:06 pm »
OK, I clicked on the Globe and found your site https://taradov.com/, very nice!
May I be bold and ask just what you do at Atmel?
Alan
Offline ataradov
    • Personal site
« Reply #17 on: September 25, 2018, 08:20:08 pm »
Applications engineering and customer support mostly.
Alex
« Reply #18 on: September 25, 2018, 08:44:58 pm »
Well you have been good on the customer support area. I can attest to that.
I like using your startup example you gave me to begin building on. How should I start a new project in Atmel Studio without Atmel adding in their startup code? Or should I start there and clear out their stuff, then add your framework? How to handle your library file, etc.
Offline ataradov
    • Personal site
« Reply #19 on: September 25, 2018, 08:48:17 pm »
No idea. I think there is an option to start with a clean project. But AS has a nasty habit of not putting header files along with the project. It tries to use header files from the packs, so if you archive the project, you won't get the whole thing.
You already have my projects. Just start with that. This is exactly why they exist - I got annoyed with how hard it is to start with a clean slate.
Alex
« Reply #20 on: September 26, 2018, 01:20:56 pm »
I will use your framework.
Thanks again for all your help Alex.
« Reply #21 on: September 26, 2018, 09:26:01 pm »
Alex
When you did the ADC testing, was that on the SAMC21 Xplained Pro board?
That is what I am testing with here and when I ground ADC0 input, I'm not getting a readings of 0. This is on the analog header, pin labeled A0 (PB09).
Alan
Offline ataradov
    • Personal site
« Reply #22 on: September 26, 2018, 09:35:14 pm »
Yes, I was testing it on C21 Xpro.
If you have a different board, then you need to adjust the pins accordingly. The code is written to read the pin PA02 (AIN[0]).
You would need to change HAL_GPIO_PIN(ADC... and ADC0->INPUTCTRL.reg assignment. Everything else should be the same.
« Last Edit: September 26, 2018, 09:36:49 pm by ataradov »
Alex
« Reply #23 on: September 27, 2018, 05:24:44 pm »
I got it working now.
I was grounding all of the A/D input on the A/D connector while taking readings, however the channel you selected in your test code was on an A/D channel over on the D/A output connector. That caught me off-guard! :)
Thanks,
Alan
Offline ataradov
    • Personal site
« Reply #24 on: September 27, 2018, 05:35:10 pm »
What board are you using?
Alex
