Author Topic: Wich Programmer for MachXO2 FPGAs?  (Read 5832 times)
Offline HagridTopic starter
« on: January 07, 2018, 11:19:08 am »
Hello everyone, I am looking for a JTAG programmer to flash the MachXO2 FPGAs from Lattice.
Since I am quite new to FPGAs, I am not sure which programmer I will need.
There are some clones of a Lattice programmer on Ebay.
The description of these clones usually has listet the supported FPGAs.
The MachXO is always listed, but the MachXO2 and the MachXO3 not.
I wonder if these are supported too.
Greetings, Hagrid  :)
Offline daveshah
  • Country: at
    • Projects
Re: Wich Programmer for MachXO2 FPGAs?
« Reply #1 on: January 07, 2018, 11:38:15 am »
I use the FTDI C232HM-DDHSL cable which is detected as an official programmer by Lattice's tools, and reasonably priced. However for some devices you may need a tiny bit of capacitance, around 18pF, added between the TCK pin and ground.
The following users thanked this post: Hagrid, m98
« Reply #2 on: January 07, 2018, 12:51:15 pm »
Thanks for the hint! It is really a lot cheaper than the official programming tool.
I am very unfamiliar with JTAG. Do I need to do some configurations to get the adapter working?
I have read somewhere that all JTAG programmers do almost the same but need to be configured for different parts.
Offline SiliconWizard
« Reply #3 on: January 09, 2018, 04:07:19 pm »
Lattice tools can be used with any FT2232H that's properly configured. MPSSE (needed for JTAG) is on channel A of the FT2232H. Look at the MachXO2 breakout board schematics to see how it's connected to the MachXO2. Attached is a configuration template for FT_PROG that works (in a zip file, the forum doesn't allow xml files apparently).
