Author Topic: Which microcontroller should I learn?  (Read 72284 times)
0 Members and 14 Guests are viewing this topic.
Offline pmbrunelle
  • lost mech. guy
Re: Which microcontroller should I learn?
« Reply #25 on: February 08, 2016, 04:53:14 am »
Some people will say you should learn ARM or whatever, but with modern coding practices the core is irrelevant. The biggest hurdles are learning how the peripherals in a specific MCU work (which may vary greatly even within the same family) and how to use the vendor's IDE, frameworks, debugging tools etc.
If you're programming in C, not assembly, then I don't see what the difference is.
I know of one product that has two microcontrollers in it: one is TI, one is Freescale. The programmers on the project were expected to adapt to the differences between the two - and they did.
Learn to program any microcontroller in C, and then the skills will be transferable.
Offline westfw
« Reply #26 on: February 08, 2016, 04:59:36 am »
Learn a BUNCH of different microcontrollers.   Note that "ARM" is NOT a microcontroller; it's just a CPU/Core.  There are too many vendors with significantly different stuff around the ARM bits (which is programmed in C and largely irrelevant anyway.)
You're probably better off learning about applications than chips (the root of the "learn better programming" comment.)  If I want to hire someone to do work on my IoT networking widget, then I want someone who understands networking and/or sensors/etc.  Not necessarily someone who understands the cpu core of the chip I'm using.  Ditto if I'm making a quadcopter; understanding motors and guidance sensors is more important than chips.    You came out of university; you're supposed to be intelligent and flexible enough to LEARN a new chip.
Offline eck
« Reply #27 on: February 08, 2016, 07:56:27 am »
Among other things, I would like to know which microcontroller is most in demand now and for the foreseeable future.
Maybe a bit outdated, but still interesting:
http://bd.eduweb.hhs.nl/es/2014-embedded-market-study-then-now-whats-next.pdf
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #28 on: February 08, 2016, 07:57:26 am »
I also came from Arduino and my next step was using a bare-bones AVR chip in a project and using the Atmel Studio for IDE. That forces you to read the datasheet and step down a level in code. You learn a lot. After that pick an MCU that fits what you're doing (or want to do). I am currently fiddling with the Cypress PSoC-5 (Programmable System on Chip - so CPU -ARM3- and programmable logic) which is good fun.
My main criteria for selecting a direction is the IDE. That is where you spend most of your time.
[2c]
Wrong code should not compile!
Offline nctnico
Re: Witch microcontroller should I learn?
« Reply #29 on: February 08, 2016, 09:13:12 am »
learn good programming instead
Well, that's no help...
Actually it is a good suggestion. Invest in some good books on this topic. For example: 'Making embedded systems' by Elecia White is a good book to get started on embedded programming. What makes a good programmer is the ability to divide a complex problem into manageble pieces and layers. C++ data structures is another one I like. I think we'll be seeing more C++ used on microcontrollers so if you know some C++ you'll have some advantage over other applicants.
Offline legacy
« Reply #30 on: February 08, 2016, 10:13:02 am »
precisely
Offline Throy
« Reply #31 on: February 08, 2016, 11:48:41 am »
I agree with learning to program first.  The rest is just being able to read datasheets IMO.
Offline spudboy488
« Reply #32 on: February 08, 2016, 12:50:46 pm »
Here's a thought which was lightly touched. As the OP is basically asking what to learn to become a professional, I would suggest looking at the job advertisements in the field/companies that you would like to work for and see what they are looking for. Sure, it would be great to learn CPU X or IDE Y but if the hiring companies are not looking for people versed in CPU X or IDE Y, you are out of luck. Since you're starting fresh, pick something that has a current market demand to make yourself a better candidate for the position.
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #33 on: February 08, 2016, 05:25:59 pm »
So you think he should just stick with the Arduino?
Offline MT
  • Country: aq
« Reply #34 on: February 08, 2016, 05:41:14 pm »
Every time this kind of questions pops up it's answered at least twice with: 8 bitters because they are inside every refrigerators, toasters, and electric BBQ's etc etc etc! Humbug!
« Last Edit: February 09, 2016, 01:49:40 am by MT »
Offline tggzzz
« Reply #35 on: February 08, 2016, 06:20:58 pm »
So, I would like your opinion on which microcontroller should I learn....
I would like to go from a hobbyist to a professional, my goal is to work on product development.
It doesn't matter which one you learn for many reasons, including:
  • your first employer will use a different MCU
  • any specific MCU will be obsolete in three years time, and then you will incorrectly think you are back at the beginning
  • horrifyingly little has changed since the 1980s. It took me longer to choose and install the development tools than it did to get up to speed on modern MCUs.
Back in the 1980s I was programming Z80s+IO boards and ARM devices, cross-compiling C on Xenix, using in-circuit emulators when debugging.
Now I am programming atmega328 and ARM,  cross-compiling C on Linux, using JTAG when debugging.
There is very little difference between the Z80+IO boards and the atmega328.
JTAG gives the same facilities as in-circuit emulators.
Linux = Xenix, at this level.
The only real difference is that in the 1980s I couldn't have afforded the equipment and that it was much larger.
So, concentrate on learning the timeless fundamentals of system design, program and hardware design, and debugging. That will last decades not years.
Then demonstrate that you have set yourself a difficult target, made many mistakes, know how you would do better next time. Employers love that.
Offline Aodhan145
« Reply #36 on: February 08, 2016, 06:37:57 pm »
If you're interested in ARM, there is an online course from University of Texas that started this January 20:
https://www.eevblog.com/forum/beginners/free-course-ut-6-03x-embedded-systems-on-edx-starting-now/msg846982/#msg846982
Although it already started, I guess you can still enroll. The course is based around the TI implementation of ARM (TM4C123), and you can get the evaluation board directly from TI: https://store.ti.com/Tiva-C-LaunchPad.aspx. I got mine delivered in 4 days, to Sao Paulo.
I didnt like that course. It was way to long/bulky for the little information in it.
Offline legacy
« Reply #37 on: February 08, 2016, 07:02:17 pm »
nostalgia makes itself called 3 3 2
Back in the 1980s
bought for a sentimental affection for the past,  for a period with happy personal associations
when Unix was not linux, and tools were not open source  :D
Offline dannyf
« Reply #38 on: February 08, 2016, 08:29:02 pm »
I don't think employers are looking for knowledge on particular chips, or even peripherals though farmiliarity with them is helpful.
It is unlikely that as a beginner you will be hired into a senior role without any supervision or training. So your ability to get up the learning curve, coding in a robust way, and good working experience with those chips are far more important than specific knowledge on a particular chip - it is unlikely that your next employer will hire you explicitly to work on that chip.
Offline lem_ix
  • Country: cs
« Reply #39 on: February 08, 2016, 09:55:14 pm »
As people have previously mentioned, learn proper programming first. If you have an arduino uno (or w/e) maybe it would be a good idea to program it from Atmel studio in C for a start. You can even do it over usb with some tweaking, no programmer or ftdi required.
When you understand what you're doing on the arduino (atmel atmega328p) switching to any 8-bit mcu won't be difficult. After that go for some ARM and freertos or w/e seems fun.
Offline westfw
« Reply #40 on: February 08, 2016, 11:14:48 pm »
[68332 eval board] [the 1980s] when Unix was not linux, and tools were not open source
gcc for 68k pre-dates the 68332 by a bit...
Before that, you got a C compiler with your unix system.  Usually based on the Portable C Compiler.  (gcc was better.)
Offline pmbrunelle
  • lost mech. guy
« Reply #41 on: February 08, 2016, 11:36:50 pm »
OP should stick with Arduino if it's easiest, but use a more standard IDE, and avoid the Arduino libraries.
More importantly though, don't just use a microcontroller to make LEDs blink for no reason.
Use a microcontroller as part of a larger project. Since you say "mechatronic" (does that mean sort of mechanical?), then something has got to move as well. So for example, make a robot dance. Show the range of your skills, don't just focus on one part.
I never learn anything in isolation as a text-book exercise. For example, I never did a standalone op-amp filter. Instead, I decided to build speakers, and then filtering became a necessity. From there, I became motivated to learn about filtering, and I also had realistic design constraints rather than designing something for no reason.
Offline legacy
« Reply #42 on: February 08, 2016, 11:55:33 pm »
I got an ANSI C compiler for HPUX/PA1, it was not based on Portable C Compiler
It was made by Avocet Systems, they made a lot of ANSI C Cross-compilers for 8051 family, 68HC11, m68k
and their software was supporting a few commercial Unix such as SunOS, SGI IRIX, HP-UX/PA1, HP-UX/PA2, IBM RS/6000 AIX
in my opinion it's better than GCC (from v2.93 to 3.*) by different orders of magnitude!
SierraC runs on DOS, Motorola included a copy with the BCCDI board
(which means the top gun, debug processor, MC68881, NVRAM and software, ~4000 USD)
in my opinion, after a recent experience: it's the funniest compiler ever tried on dos !
« Reply #43 on: February 15, 2016, 02:16:42 am »
Good programmer can write good code even with Arduino
even if arduino is good for rapid prototyping, there are at least three negative aspects
1) arduino's examples, libraries, etc, are (just to use an euphemism) usually not so good
Got to give you that one, the existing library code sucks rocks in places. The APIs are harmless enough though, even if not the most polished.
2) arduino call the programming "sketch" instead of "code"
Well those of us who've been doing this a while tend to call it a 'program' but we won't arbitrarily discriminate against you for calling it a 'code' as long as you don't discriminate against others because they haven't been around as long. However, what the IDE calls a project/program/whatever isn't exactly a reliable metric for how good an IDE it is.
3) arduino doesn't have the concept of "module"
You do realise that the Arduino IDE uses the GCC C++ compiler don't you? There is absolutely nothing stopping you writing full C++ classes and the IDE is kind enough to figure out what you're going and just magically compile any other source files you stick into the folder with your .ino file.
In fact I rather like the Arduino IDE. It's simple, efficient and doesn't get in the way. In the time it would take me to get Eclipse or something similar downloaded, configured and working I could download and install the Arduino IDE, write my code and be finished before I'd typed one line of code into Eclipse. But I've only been doing this programming lark since 1975 so I probably don't know what I'm talking about.
Offline legacy
« Reply #44 on: February 15, 2016, 08:22:05 am »
edit: rewritten in more polite form, I would avoid to summarize with too harsh referring to something unpleasant or embarrassing, instead I will use the expression "code definitely downsizing as a euphemism for their cuts", just to underline the possibility they can "improve" :-+
(even if silly blocking-code is still present in their libraries, even the documentation is downsized in quality and still too bugged :palm: :palm: :palm: :palm: )
the Wiring behind the hood makes the difference between "sketch" and "program"
which is bad for code analyzers.
knowledge and insight, the toolchain has absolutely no relation with the importance of being able to code with modularity in mind.
Once again arduino guys have proved to have absolutely no idea about that.
« Last Edit: February 15, 2016, 11:26:42 am by legacy »
Offline legacy
« Reply #45 on: February 15, 2016, 08:37:20 am »
it's a mashup between electronics and mechanics, imagine a course where you study mechanics integrated with electronic, it's more mechanics than electronics, you can say electronics applied to mechanics
in my opinion, I believe your advice - don't learn by exercises which focus on reduced knowledge and didactical insight, learn by the whole projects as multidisciplinary synergy - is the best one  :-+ :-+ :-+ :-+
Offline Roicker
  • Country: mx
« Reply #46 on: February 16, 2016, 09:31:41 pm »
First things first... TL; DR; If you want to learn embedded seriously, buy something that is not an Arduino. My recommendation? The TIVA C for $12 + shipping
I think I may be qualified to answer the OP's original question. I have a B.S. in Mechatronics, M. Sc. in Control and I work as the SW Group Leader of a big Tier 1 (we sell to most of the automotive OEMs of the world) that makes ADAS Sensors. I'm not bragging, I just bring this up to try to explain why I think I'm qualified to give a relevant opinion.
I've hired a lot of people over the last years for the position of Embedded SW developer for Instrumentation Displays (Clusters) and ADAS Sensors and one thing that I really don't like to see in a candidate is when they say they know embedded because they have programmed in Arduino. Let me explain this: I don't think arduino is bad, it's actually a great tool (I have one in my 3D printer) for when you want something cheap and that can be reproduced by many, but if you only have used it with the libraries that come with it, or you bought a shield and downloaded code from somewhere... well I don't think I would be very interested in hiring you in that case. The problem in an interview is to separate the people that actually learned with an arduino from the people that only downloaded code and connected some cables.
If you have used Arduino for doing something complex (like program Ardupilot or Repetier for a 3D printer :P) well then it's easy for me (and any interviewer) to see that you have potential because you took a simple tool and built something great with it.
For the reasons mentioned above I think using something like a PIC, an ST or TI ARM or even an AVR Mega (I know that is the MCU of the Arduino, but I mean directly without the code base) is better for actually learning Embedded Systems. The current toolchains have the basic startup for the MCUs but after that, you need to analyze examples and read datasheets to understand how to setup and use the peripherals and debug SW by checking how the system is behaving after each step. These things are what we are looking for in embedded SW devs, engineers that can analyze requirements and write code to realize them and if something goes wrong DEBUG IT! With an Arduino most of this has been done, all you have to do is call a function. Also, the toolchain doesn't allow you to do in circuit debugging as far as I know you can only "code and pray" that it works.
The main problem with Arduino for me is: It makes it too easy! that is great if you don't want a career in Embedded SW, but if you do, I recommend something else.
My personal recommendation (because I've bought a couple of kits and worked with several MCUs) is the Tiva C from Texas instruments. Why?
1. The thing is cheap ($12) dlls plus shipping, but if you bundle that with other components you may need it's ok
2. Has good support from a community (it's obviously not as good as arduino but it works)
3. You have an In-Circuit Debugger included for free, which means you can execute your code step by step, set breakpoints, see the memory, etc. and all of this is great for learning and debugging
3. It has code examples and tutorials to teach you the basics because it's aimed at the DIY community
4. As long as you are using that board the compiler and toolchain are free with unlimited code size
5. It has a fast ARM Cortex M4F (with floating point) and it has a lot of peripherals
hope this helps!
Offline f4eru
    • Chargehanger
« Reply #47 on: February 16, 2016, 10:43:32 pm »
Any uC which has good community support, openly supported programming tools, and GCC as a compiler.
So with many ARM uCs, you are spot on. Some can be programmed just by connecting to USB -> no need for any tool inbetween -> just put a USB connector on your board -> nice way to do it
For smaller parts, the mega AVRs are nice.
Well structured C is a must to learn (not C++)
« Last Edit: February 16, 2016, 10:45:31 pm by f4eru »
Offline dannyf
« Reply #48 on: February 16, 2016, 10:59:18 pm »
If you are learning as a hobbyist, the choice of mcu doesn't really matterm. And 8bitters like avr and stm8 are fairly good. Pics have a large code base.
If you intend to make a living out of this, arm is the way to go.
Of the major vendors, TI offers some of the most feature rich chips, but tends to have questionable adc modules. STM has a lot of offering and great prices. But aren't that great in terms of features and quality. Nxp has a lot of consistency in its peripherals and is generally bug free. Freestyle is great in mixed signal, and its middle ware (PE) is the best in class. Cypress is a small player but offers innovative solutions.
Myself uses a lot of ST products out of historical reasons - I used to be a heavy LM3S user.
Offline nctnico
« Reply #49 on: February 16, 2016, 11:06:11 pm »
For hobby use I'd definitely go for ARM as well. 8 bitters (the word already says it: bitter) are based on convoluted archaic and slow architectures which just get in the way of making something cool. With ARM you don't have to worry so much about code size, different kinds of memory, absence of a real stack and no real support for pointers. I have wasted too many hours on trying to get around the limitations of the 8051!
