First things first... TL; DR; If you want to learn embedded seriously, buy something that is not an Arduino. My recommendation? The TIVA C for $12 + shipping
I think I may be qualified to answer the OP's original question. I have a B.S. in Mechatronics, M. Sc. in Control and I work as the SW Group Leader of a big Tier 1 (we sell to most of the automotive OEMs of the world) that makes ADAS Sensors. I'm not bragging, I just bring this up to try to explain why I think I'm qualified to give a relevant opinion.
I've hired a lot of people over the last years for the position of Embedded SW developer for Instrumentation Displays (Clusters) and ADAS Sensors and one thing that I really don't like to see in a candidate is when they say they know embedded because they have programmed in Arduino. Let me explain this: I don't think arduino is bad, it's actually a great tool (I have one in my 3D printer) for when you want something cheap and that can be reproduced by many, but if you only have used it with the libraries that come with it, or you bought a shield and downloaded code from somewhere... well I don't think I would be very interested in hiring you in that case. The problem in an interview is to separate the people that actually learned with an arduino from the people that only downloaded code and connected some cables.
If you have used Arduino for doing something complex (like program Ardupilot or Repetier for a 3D printer
) well then it's easy for me (and any interviewer) to see that you have potential because you took a simple tool and built something great with it.
For the reasons mentioned above I think using something like a PIC, an ST or TI ARM or even an AVR Mega (I know that is the MCU of the Arduino, but I mean directly without the code base) is better for actually learning Embedded Systems. The current toolchains have the basic startup for the MCUs but after that, you need to analyze examples and read datasheets to understand how to setup and use the peripherals and debug SW by checking how the system is behaving after each step. These things are what we are looking for in embedded SW devs, engineers that can analyze requirements and write code to realize them and if something goes wrong DEBUG IT! With an Arduino most of this has been done, all you have to do is call a function. Also, the toolchain doesn't allow you to do in circuit debugging as far as I know you can only "code and pray" that it works.
The main problem with Arduino for me is: It makes it too easy! that is great if you don't want a career in Embedded SW, but if you do, I recommend something else.
My personal recommendation (because I've bought a couple of kits and worked with several MCUs) is the Tiva C from Texas instruments. Why?
1. The thing is cheap ($12) dlls plus shipping, but if you bundle that with other components you may need it's ok
2. Has good support from a community (it's obviously not as good as arduino but it works)
3. You have an In-Circuit Debugger included for free, which means you can execute your code step by step, set breakpoints, see the memory, etc. and all of this is great for learning and debugging
3. It has code examples and tutorials to teach you the basics because it's aimed at the DIY community
4. As long as you are using that board the compiler and toolchain are free with unlimited code size
5. It has a fast ARM Cortex M4F (with floating point) and it has a lot of peripherals
hope this helps!
