Dave, I take it that there is no way to eliminate the double line "started by Mr. X" bit in the title column? I think you may have reduced the font size, but it's still bloody annoying. The actual "title" is in a softer color than the "posted by" line, so it's still partly drowned out by the more insignificant information.
I may be overly sensitive to this though.... I'm currently under the gun with "efficiency improvements" in my company.... we're changing to a work method that was found to be inefficient and dangerous 20+ years ago because our new/old management has decided it's more efficient, logic and common sense be damned. And to make matters worse, McDonalds has changed THEIR methods as well.... I had to stand and watch a McDonalds cashier stand there, after having taken my money for a large coffee, and do absolutely nothing, because it was not her job to actually turn around and get my coffee, anymore........ These new University trained efficiency experts should be informed that an expert is defined as nothing more than "X" is the sign of an unknown, and a spurt is a squirt under pressure!
Regards
Kaptain "I give up, I just don't care anymore" Zero
