Author Topic: Beginner on TL866 needs some help  (Read 2095 times)
Offline orgamishoTopic starter
  • Country: bg
« on: January 31, 2021, 08:16:52 am »
Hello all!
I am repairing  a device and to do so I have to reprogram the nand flash in it. I've successfuly read the nand and I found the data I need to change before programming it back to the nand but it seem that the data is grayed out and I can not change the cells.
I am using TL866ii PLUS with xgpro v10.75 software
Thank you in advance!
Offline Bicurico
  • Country: pt
  • Broadcast Systems & Transport Stream Analysis
    • VMA-Broadcast
Re: Beginner on TL866 needs some help
« Reply #1 on: January 31, 2021, 09:23:42 am »
You need to edit the data with a hex editor.
I usually use Notepad++ with the hex editor plugin.
Regards,
Vitor
  • Country: bg
« Reply #2 on: January 31, 2021, 11:28:02 am »
Unfortunately Notepad++ coould not open the file as it is doo big, but tried with a different hex editor and it worked!
Thank you!
