Poll
Do you like Python?
Yes, I love it.
22 (24.2%)
Yes, I like it.
24 (26.4%)
No, I don't like it
17 (18.7%)
No, I hate it.
14 (15.4%)
No opinion, indiferent
11 (12.1%)
I refuse to answer
3 (3.3%)
Total Members Voted: 90
Author Topic: Python becomes the most popular language  (Read 275118 times)
0 Members and 12 Guests are viewing this topic.
Offline RoGeorge
Re: Python becomes the most popular language
« Reply #1000 on: March 21, 2024, 12:14:13 pm »
KDialog from simple shell scripts.  The exit status will correspond to Ok/Cancel/Window closed, and any selections will be printed to standard output so you can safely capture it.
Wow!  I knew I can pop a MsgBox from a .vbs in Windows, but I didn't know Plasma can do the same.  ;D
There are some misconceptions that Plasma is only a graphical environment. While it is true that Plasma is an outstanding desktop environment, the Unix heritage of command line and scripting is also well supported by Plasma. In particular, KDE applications can be controlled from the command line, and shell scripts can make use of some of the KDE widget set.
Quote from https://develop.kde.org/docs/administration/kdialog
That will cover 9 out of 10 situations with zero GUI programming overhead, perfect for my use case, thanks!  :-+
The following users thanked this post: Nominal Animal
