Author Topic: Q: (better) alternative for OPA627 ?  (Read 26061 times)
Offline KjeltTopic starter
« on: May 23, 2016, 09:31:38 am »
Hi since end of the 90's the OPA627 has been a very good audio grade operational amplifier.
Specs: Very Low Noise: 4.5 nV/vHz at 10 kHz but they are pricy (€40/pc) !
They are still manufactured and available.
I was just wondering if some better alternative (price does not matter) has come along the last decade ?
What is the nr1 opamp choice for ultra low noise audio applications today for new designs or is this still the device to use?
Re: Also take a look on OPA1662
« Reply #4 on: May 23, 2016, 10:32:03 am »
http://www.ti.com/lit/ds/symlink/opa1662.pdf
Thanks for the opa1662 , will check it out. It does not have the offset trim inputs, are the new ones that good they don't need them anymore or whats the story?
Offline Marco
Re: Q: (better) alternative for OPA627 ?
« Reply #5 on: May 23, 2016, 10:39:40 am »
Why would you care about offset for audio?
« Reply #6 on: May 23, 2016, 10:46:10 am »
I don't know, I am not an analog expert, I just saw that this is a difference and wondered if it mattered.
Also the 1662 contains two opamps, does that have implications like crosstalk or mutual influence ? Probably also not that big deal in the audio frequencyband.
« Reply #7 on: May 23, 2016, 11:16:22 am »
There are many Chinese distributors can give you very low prices than from the western because we believe the cheaper the more competitive, HOWEVER, no one can get goods less than manufacturer's price, so if the price is lower than TI's high volume MSRP (~50%~80% of 1kpcs price), then it MUST be fake.
OPA627 sells for $12.86 in its cheapest package, even at mass quantity it sells for only 50% its 1k price, that's $6.43, or ~42 CNY, anything brand new and cheaper than this price is fake.
Agree, only exception is  overstock or overdate , when a manufacturer finished production and some partly used reels are left they can be very cheap, also when the expiry date on the reel is nearby or passed they can become very cheap since no respectable manufacturer will take a chance that too high part of the production will have problems. For hobbieists this can be real good usable sources of components.
« Reply #8 on: May 23, 2016, 11:25:12 am »
No indeed for some of the prices you see at those chinese sites that is almost giving them away and should trigger the "fake" alarm with anybody who is serious.
Offline Kleinstein
« Reply #9 on: May 23, 2016, 04:17:40 pm »
It depends on the circuit you use the OP. In some circuits even the LM358 could be better. If lowest noise is needed, LT1028 / LT1115 / AD797 could be an option.
« Reply #10 on: May 23, 2016, 08:33:51 pm »
I wanted to use it as an audio buffer or I->V converter after a DAC.
« Reply #11 on: May 23, 2016, 09:38:14 pm »
The Analog Devices ADA4627 is essentially a second source version of the OPA627. £4.64 GBP / €7,06 one off from RS.
Online splin
« Reply #12 on: May 23, 2016, 10:21:32 pm »
The LME49990 is a very low noise, ultra low distortion audio opamp and relatively cheap. Unfortunately it's another victim of TI retiring one of its National Instrument fabs, terminating many fine devices. You could stockpile - not sure if they have ceased production yet.
Alternatively the NE5532/NE5534 are fine low cost, low noise amps used extensively in audio. This is well worth reading:
http://nwavguy.blogspot.co.uk/2011/08/op-amps-myths-facts.html
Offline The Soulman
  • The sky is the limit!
« Reply #13 on: May 23, 2016, 10:45:15 pm »
TLE2071, OPA604, could be better could be worse, it depends.
Online nctnico
« Reply #14 on: May 23, 2016, 11:09:14 pm »
The venerable TL074 also comes to mind. On paper more noisier but the parts around it can also add noise.
Offline Zeranin
« Reply #15 on: May 24, 2016, 08:37:57 am »
I'm fond of the OPA627, though not convinced that it's strengths (low Ib and current noise combined with fairly low voltage noise) are usually required in audio applications.
I once bought some off the net because my normal supplier was out of stock, and they were fakes. I would recommend buying only from well-known, reputable suppliers, and any price that seems too good to be true almost certainly is.
Offline BarsMonster
    • Microchips internals
« Reply #16 on: May 24, 2016, 07:04:59 pm »
Early warning: there are lots of fake (!!!) NE5532 on ebay. We'll feature that soon on the site.
Microchips internals: http://zeptobars.com/
The following users thanked this post: kony
« Reply #17 on: May 24, 2016, 07:38:22 pm »
Unless it's from a known and trusted supplier it would be wise for one to assume that from ebay, aliexpress etcetera that any op-amp that's in any way 'premium' is a fake. The stepping point from probably good to probably fake is somewhere just above LM358. Incredibly I've got some TL072s that are fakes, with obvious 'blacktoping', parts that I really didn't think it was worth anyone's time to fake.
Offline ebclr
« Reply #18 on: May 25, 2016, 03:25:31 pm »
To good to be true.
Try before label as fake...
Many reasons to find chips undervalued, like excess inventory, end of production, company bankruptcy and many other ones.
Fake or not fake is not the matter the matter is work or not.
By experience all so called fakes works fine, and at least 80% do exactly as the datasheet describes, You are fool enough to pay 20 times more for something to be real not fake etc etc it's up to you.
Ei incumbit probatio qui dicit, non qui negat    even for ic's this can be true
« Reply #19 on: May 25, 2016, 06:10:11 pm »
To good to be true.
The number of sources of low cost parts for the legitimate reasons you've listed are dwarfed by the number of fakes. I do buy lost cost parts that are low cost for legitimate reasons from British and Polish suppliers that I've used before. I have a, thankfully small, collection of fake parts from trial purchases made from, lets say, 'countries in the Pacific Rim'.
If you've had fake parts where "80% do exactly as the datasheet describes", what do you do about the 20%. Solder them into a circuit and pray? Do 100% incoming component inspection on them? The latter, if you're equipped to do it, rather takes away the cost advantage of grey market parts.
Plus the usual fundamental arguments about fakes apply: you're taking money away from the legitimate developers of the part, and hence stunting future R&D, and funding, frankly, criminals. Your application might be non-critical, but god help us if some of those "80% OK" parts find their way into a safety critical system. etc. etc.
What about Caveat Emptor, rather more germane I'd have thought than a Latin tag about criminal law.
Online wraper
  • Country: lv
« Reply #20 on: May 25, 2016, 06:20:08 pm »
I have read like this in one audio forum  :palm:. "If it sounds good, does not matter if it is fake"  :-DD
Why the hell would you buy some unknown cheap opamp labeled as more expensive stuff, if you can just buy decent cheaper opamp without any lottery.
Rarely the case with China, usually you just get cheap crap. Yeah, they work, but not as well as genuine ones, and not up to the datasheet spec. Probably this will remain unnoticed in audio applications, but if they go in some kind of precise equipment, can cause tons of weird problems.
Offline zlymex
  • Country: cn
« Reply #21 on: May 26, 2016, 02:33:59 am »
For my own use/test, I buy reclaimed ICs with original marking and original leads. They are very cheap and genuine most of the time.
Measurement is Comparison.  https://bbs.38hot.net/
Offline Zeranin
« Reply #22 on: May 26, 2016, 04:15:06 am »
To good to be true.
What on earth does 'works fine' mean?? Sure, the fake OPA627's that I bought 'worked', but they did not meet the specs for an OPA627, so were no use in any critical application that required the OPA627 specs, so I threw them in the rubbish bin where they belong.
If all you want is an op amp that 'works', then you are much better off just to buy a cheaper op amp in the first place.
If your demanding application requires an expensive, high-performance op amp, then fakes are also of no use.
Summary, fakes are not of any use to anyone.
What exactly is a 'fake' IC? I always assumed that it was a re-badged product, and done as a 'backyard' industry.
One cannot literally make an IC, and especially a high-performace state-of-art IC, in a backyard, or even in a small tinpot factory. Is there even such a thing as a 'fake' IC made in some no-name, large factory in China or similar? If any company and factory has the engineers and expertise to actually make IC's, then why would they need or want to make 'fake' ones anyway?
I tend to think that fake ICs are simply backyard rebadged ICs. Does anyone have evidence of fake ICs being manufactured, rather than re-badged?
Offline zlymex
  • Country: cn
« Reply #23 on: May 26, 2016, 10:05:17 am »
That's right, they all from underground. There are actually three types of fake ICs:
 - retreated. they are the same ICs(could be different suffix), re-tinned, re-marked so that they look new.
 - shoddy, functionally are the same but vast and cheaper to get. For instance use uA741 for OP07
 - fake, they use arbitrary ICs of the same package, re-mark anything they want.
I've encountered all three.
Online wraper
  • Country: lv
« Reply #24 on: May 26, 2016, 10:30:50 am »
FTDI FT232RL, Nordic nRF24L01
As of opamps, IMO in 95+% of the cases they are just rebadged.
