You haven't really provided a design, more of a concept. In theory what you've described will work, but the devil is in the details. The specific power supplies you have in mind, how well matched your LEDs are to one another (cheapo high power LEDs tend to have substantial parasitic parallel resistance which affects their V/I curve beyond the normal diode parameters), how exactly you distribute the 60A from your power supplies to the LEDs, and a number of other factors will all affect how WELL it will work.
10klm sounds rather hopeful for 100W LEDs, the cheap ones I see on Amazon all claim 8-9k. With cheap electronics, usually the claimed performance is inversely proportional to the quality, so beware.
Generally you want to run LEDs in constant current mode, but the high power chip arrays often get away with CV due to parasitic series resistance and the fact that voltage changes are split across large series strings. Hopefully you'll at least be able to trim your PSU output voltage a bit to get your current in the right ballpark.
