Author Topic: 107 volt regulator  (Read 1701 times)
Offline BurningTantalumTopic starter
107 volt regulator
« on: December 23, 2017, 12:13:18 pm »
A non-technical friend called to say that he had acquired a box of "those things that you have in your workshop" and did I want it, so I told him to bring it round. It was a huge cardboard box full of electronic components, some in ziplock bags, some loose. It has taken me all afternoon to sort them into heaps on the dining table- anything with 3 legs in one heap, ICs in another heap, caps, diodes, connectors etc. I think that it came from an electronic supplier that closed down many years ago in a town down the coast. Many of the plastic bags have flaked to bits with UV exposure, so I grabbed handfuls of loose components and sorted them roughly.
One component (among many) caught my eye. It is a STR440 in a modified TO3 case (3 legs.). I cannot find any data on this, other than it is a monolithic 107V output 0.6A regulator.
I don't recall seeing anything that needed 107V specifically.
Any ideas for its intended use?
I have seen the 3 leg TO3 case style only once before, and it was a high-voltage switching transistor by Motorola used in a vehicle ignition system.
Regards, BT
Offline RES
Re: 107 volt regulator
« Reply #1 on: December 23, 2017, 12:38:31 pm »
STR440 is a high (107V) voltage regulator to supply the picture tube coil of a tv.
« Last Edit: December 23, 2017, 12:41:24 pm by RES »
Offline Audioguru
« Reply #2 on: December 23, 2017, 03:28:47 pm »
Picture tube? Don't be silly, TVs don't have a picture tube and a coil, instead they have an LCD screen.
Oh, I think I remember that TVs a long time ago had a picture tube and deflection coils.
The following users thanked this post: Mr. Scram
Online David Hess
  • DavidH
« Reply #3 on: December 23, 2017, 07:28:18 pm »
108 volts is also common in oscilloscopes which may have something to do with being twice 54 volts.
Offline jaycee
« Reply #4 on: December 24, 2017, 12:41:12 am »
Sanken commonly made modules like this and judging by the part number it's one of those!
Offline Mr. Scram
  • Display aficionado
« Reply #5 on: December 24, 2017, 12:54:39 am »
You did a funny!
« Reply #6 on: December 24, 2017, 03:23:41 am »
Thanks everyone- I knew that someone would know!
Happy New Year,  BT
Offline Cyberdragon
« Reply #7 on: December 25, 2017, 04:03:08 am »
What is this antique tech you call an LCD? Everybody knows TVs have OLEDs. ;)
*BZZZZZZAAAAAP*
Voltamort strikes again!
The following users thanked this post: 001
