I don't quite understand "220V" being wired to a CD4093 logic gate.
To let the SMPS be connected to neutral (not floating), I decided to let my circuit be the floating one. So, its ground is connected to the hot line.
You are right. The word '220V' is misleading here. But my assistants whose English is rather very weak are used to hear it (220V) as being 'the hot line'.
Better names I guess would be "220V" --> "HOT", "NTR" --> "NEUTRAL", "SMPS" --> "LOAD"; "220V" net bridged to a "VDD" or something like that, and "GND" can be a high side VEE, or floating GND or something like that, maybe it's fine to leave as "GND" as such but just as long as it's clear. A connected drawing would be easier to make sense of than net labels, making it clear that the logic side is "hanging below" one AC line, and there is a series bridge element connecting the load.
All you said makes sense. But when I drew it, after many other design failures and for in-house use only (that is just for me), I didn't notice that its schematic became clear to me only
Please note that the regulating circuit is done for SMPS specifically (not any load). Therefore, no one here will likely be interested in keeping a conventional 220V SMPS running normally at high voltages. Usuallly, a simple passive protecting circuit (as the one at post #11, for example) could be enough in most applications.
So I guess the point is a dropper to limit load voltage? But this is exactly inverse to a zener shunt, not equivalent to it!
Yes, it is a voltage dropper in series but, as I explained many times earlier, its end effect is of a bipolar zener (the positive and negative tops of the voltage sinewave are clamped, so two flat tops could be seen, exactly what a bipolar zener is supposed to do).
Yes, it is not a zener. It just regulates the AC high voltage as if it were a bipolar zener. This is why I added the word 'Virtual' in the OP title.
What current range? What fault current capacity? Not much I guess given the 1N4007s, and the poor IRFP460 will expire rather quickly under any kind of startup conditions, but maybe it'll last long enough to start a small (10s of W?) SMPS, I don't know.
It is not a general-purpose regulator. It was done for small SMPS supplies only.
The problem with putting absolutely any kind of semiconductor directly on the mains, is transients. You need at least a 1.2kV rating, with generous MOVs provided; at 400V, you're probably asking closer to 2.5kV. Even with SiC MOSFETs and a generous budget, this is a huge ask, just in switching capacity, let alone in linear operation. SiC do at least switch quickly, which suggests a more promising route: make an AC buck converter with current and voltage limiting behavior; the dropped power still must be dissipated, but it can be clamped by diodes and dumped into a generously sized resistor if nothing else.
Your remarks are interesting. If I was born and live elsewhere, I would likely need to observe them. So far, the circuit, as it is, seems working fine in my surrounding (local consumers).
Such a gross error (literally wired to the wrong power source) is best solved by a similarly gross corrective method: relay switching, or fusing. Perhaps this device is promising in certain settings, but without those circumstances set out, without any motivation, without any specification -- it just sounds like a poor attempt to deal with something that should never, ever be a "nuisance" anywhere on the planet.
I agree with you. It was not done/designed for a NASA program
About nuisance, I am afraid that, if we are realistic, there are always new devices which are created and made, almost daily, just for it
