Author Topic: Advantest R3131: Cannot set marker frq via GPIB/serial?  (Read 1165 times)
Offline YansiTopic starter
« on: April 15, 2020, 09:09:24 am »
Am I dumb or did they really forgot to add a command to set the marker frequency? It is possible to freely move the marker using the front panel, but hell I can't find any command to position the marker using GPIB/serial port.
I see only the MF? which returns the frequency marker is at, but there is none comand I can set it remotly.
Sending MF followed by a frequency does nothing.
Thanks for any hints how to do it.
« Last Edit: April 15, 2020, 09:16:03 am by Yansi »
Offline serg-el
  • Country: ru
Re: Advantest R3131: Cannot set marker frq via GPIB/serial?
« Reply #1 on: April 15, 2020, 09:58:12 am »
It depends on what you want to do.
Find the peak? Easily.
Sending a PS command.
Read the frequency of MF? .
We read the level of ML? .
« Reply #2 on: April 15, 2020, 11:58:38 am »
Finding peak is great and what not, but if I want to get the RF level at an exact frequency of interest, that for example, is not a peak? I should then try reading out the whole sample memory?  |O
Offline serg-el
  • Country: ru
« Reply #3 on: April 15, 2020, 01:23:39 pm »
Easily.
Page 4-34.
To measure the level at a frequency of 30 MHz.
Give the command MK30MZ
Give the command ML? . RTFM  ;)
The following users thanked this post: Yansi
« Reply #4 on: April 15, 2020, 02:00:32 pm »
Ah great.
They forgot to include the "MK" command in Table 4-8. Fuuuuuuuck.
"MK 405.2E6" happily moves the marker to 405.2 MHz.
Thanks for the hint!
Offline serg-el
  • Country: ru
« Reply #5 on: April 15, 2020, 02:19:55 pm »
Maybe because the MK command in table 4-7?   ;)
« Reply #6 on: April 15, 2020, 04:13:02 pm »
Well, whatever. Those tables are just mess, not  a good description of commands.
All is well now. Automated measurement done and working great, easing me a LOT of manual labor sifting through whole cartons of devices to test >:D
//Censored some work related stuff//
