Author Topic: Airsoft - paintball chrono  (Read 54330 times)
Offline vzooleTopic starter
  • Country: hu
Re: Airsoft - paintball chrono
« Reply #25 on: April 29, 2014, 03:40:57 pm »
FPS: Foot Per Second
mPs: Meter Per Second
Offline UA
« Reply #26 on: May 11, 2014, 02:07:48 pm »
Please help. I suffer for a month |O |O |O . Brazed chronograph programmed chip. When connected to electricity is off 7 segment LED display. Watching through a mobile phone camera, LED work.
But when I turn the 7 segment LED display, light some segments.
Help razobratsya what could be the problem. Thank you.
« Last Edit: May 11, 2014, 02:11:38 pm by UA »
  • Country: hu
« Reply #27 on: May 11, 2014, 02:48:05 pm »
First please take a picture about type of your 7 segment display.
Offline UA
« Reply #28 on: May 11, 2014, 05:22:07 pm »
Offline dannyf
« Reply #29 on: May 11, 2014, 06:57:25 pm »
The DP line is not connected so DP  should never be on.
Either your leds are misaligned (wrong orientation) / polarity is wrong, or the wiring is wrong.
You can correct them, or find out the real wiring and write your own firmware to it.
  • Country: hu
« Reply #30 on: May 11, 2014, 07:02:43 pm »
I checked this display and fit well in this circuit (but not upside down).
So the problem is something else.
Hard to do anything without an oscilloscope.
Offline UA
« Reply #31 on: May 11, 2014, 11:02:46 pm »
Does a problem mean not in 7 segment display? Do I understand correctly? A problem means or in details or I not correctly zaprogramiroval chip.
Offline UA
« Reply #32 on: May 12, 2014, 01:06:03 pm »
Connect power chronograph 7.5 volts. Multimeter measured current: LED - 1,18 volts, phototransistors - 0.05 volts. :palm:
Again, instead of chip ATMEGA8-PU I have is ATMEGA8A-PU.
« Last Edit: May 12, 2014, 01:42:18 pm by UA »
  • Country: hu
« Reply #33 on: May 13, 2014, 10:10:10 pm »
Can you measure voltage on resistors leg (at mcu side) which are between display and mcu?
Offline dannyf
« Reply #34 on: May 14, 2014, 12:00:46 am »
If I were to desing something like this, I would do it different: I would build it around a barrel (like a piece of pvc pipe) that can be mounted easily onto the gun. The sensors can be fixated to the side of the pipe and the display bounded on a pcb along the pipe.
It would be more rugged that way.
Offline UA
« Reply #35 on: May 16, 2014, 09:50:32 pm »
9 volt power supply. I measured the voltage across the resistors between the display and the MCU. Resistors R1-R7 (180) is zero. No stress! Resistors R8-R10 (2.2K) is 1.4 volts.
Offline UA
« Reply #36 on: May 16, 2014, 09:53:20 pm »
Here's a link to a chronograph http://chronolite2.narod.ru/ But I believe that Airsoft - paintball chrono much more practical and convenient.
  • Country: hu
« Reply #37 on: May 16, 2014, 10:06:02 pm »
Please measure it again, but now between ground and resistors mcu side leg.
Offline UA
« Reply #38 on: May 16, 2014, 10:24:08 pm »
Measured. Resistors R1, 3,4,5,6 - 5 volts. R7 is no voltage - zero. Resistors R8, 9,10 - 0,25 volts.
I measured at these points
« Last Edit: May 16, 2014, 10:34:42 pm by UA »
  • Country: hu
« Reply #39 on: May 16, 2014, 10:38:51 pm »
Thats bad, because I asked you measure on resistor leg but which is next to the controller.
Offline UA
« Reply #40 on: May 16, 2014, 10:45:57 pm »
Measured at these points
Resistors R1, 3,4,5,6 - 5,05 Volts. R7 is no voltage - zero. Resistors R8, 9,10 -. 1.65 volts
  • Country: hu
« Reply #41 on: May 16, 2014, 10:51:24 pm »
It's looks good. Can you take a picture about your transistors type?
Or make a short contact between the transistor two side leg for short time. What does it show then?
« Last Edit: May 16, 2014, 10:54:55 pm by vzoole »
Offline UA
« Reply #42 on: May 16, 2014, 11:10:36 pm »
Transistors -
How to check the transistor (if this is needed).
« Last Edit: May 16, 2014, 11:30:54 pm by UA »
Offline UA
« Reply #43 on: May 16, 2014, 11:48:48 pm »
And maybe the transistor. Need BC546, and I used BC546B. Maybe that is what affects the inefficiency? :scared:
  • Country: hu
« Reply #44 on: May 16, 2014, 11:49:58 pm »
Not...
Try this: make a short contact between the transistor two side leg for short time. What does it show then?
Offline UA
« Reply #45 on: May 17, 2014, 12:03:03 am »
I do not understand. You need to short-circuit the two legs of the transistors?
  • Country: hu
« Reply #46 on: May 17, 2014, 12:17:24 am »
Almost... make short between two side leg (E - C)
Offline UA
« Reply #47 on: May 17, 2014, 12:21:38 am »
Short circuit all three transistors?
  • Country: hu
« Reply #48 on: May 17, 2014, 12:22:15 am »
just one, any.
Offline UA
« Reply #49 on: May 17, 2014, 12:26:15 am »
Sorry, but nothing happened. The indicator has not responded.
