Author Topic: Android image processing  (Read 4093 times)
Offline KaramelTopic starter
  • Country: tr
« on: January 31, 2017, 03:52:36 am »
I have a question about this topic. I want to process a image which have taken from mobile phone's camera. Actually, I have written "android" to subject but I can also use ios platform If I have chance.
I am, now, using iphone phone and windows computer. Can I write and test any project with these equipments?
If It is not possble, I have only one option, I will have to work with android platform.
Thus, It doesn't matter any platform for me, I must take a photo and process it (taken photo must be process like just white and black and every black dots must be determined like vector)
How can I do that and where should I start? (You can also suggest book to read to me because, I am really want to read a book which is about image processing)
Best Regards,
Karamel  ^-^
« Last Edit: January 31, 2017, 03:54:29 am by Karamel »
  • Country: tr
Re: Android image processing
« Reply #1 on: January 31, 2017, 01:39:53 pm »
No idea..?  :scared:
Offline Fungus
« Reply #2 on: January 31, 2017, 02:07:30 pm »
No idea..?  :scared:
Well, this is an electronics engineering forum, not an image processing forum.
Do you go to the cinema to buy gasoline for your car?
If you feel ill do you go to a vegetable shop for advice?
Offline niekvs
« Reply #3 on: January 31, 2017, 03:15:17 pm »
Yes, you can process images with Android. There are several ways to do it: you can use the standard Android API's, which, depending on what kind of image processing you want to do (and the size of the image) may or may not give you enough performance.
You can also use RenderScript, which is a framework on Android especially suitable to parallel data processing (e.g. image filtering), as it will automatically use the multiple cores and the GPU to process your image. Read more about it here:
https://developer.android.com/guide/topics/renderscript/compute.html
There are examples that come with the Android SDK that will help you get started.
If you don't need the performance, then the standard Android image API's will be fine:
https://developer.android.com/guide/topics/graphics/2d-graphics.html
Good luck! (and use Google!)
  • Country: tr
« Reply #4 on: January 31, 2017, 03:17:27 pm »
No idea..?  :scared:
Different approach to the point.
Thanks your whole suggestions ::)
I am electric and electronics engineering students and I, now, take image processing course. What the bullshit situation for me because, Sir. Mr. Fungus said this is irrelevant thing about electronics engineering and unfortunately, he is exactly right.
I am leaving my school  ^-^
  • Country: tr
« Reply #5 on: January 31, 2017, 03:20:33 pm »
Thanks for all information. I will investigate it and will write results of my project here ::)
Offline Fungus
« Reply #6 on: January 31, 2017, 05:35:06 pm »
Just pointing out the reason why you might not get any replies here.
I'm sure there are people here who do image processing in these forums but ten seconds with google should find you a better place to start.
PS: Anybody got a good recipe for carrot soup?
  • Country: tr
« Reply #7 on: February 04, 2017, 03:58:40 pm »
I got your idea, I had searched it on internet, after I asked.
So, why I asked it?
Because, I needed to direct correctly via mentor people. There are some solutions okay but, for example, mentors say that don't look at them or don't deal with them.
Starting point is the most important thing. I think, you got me.  ^-^
Offline amanda1
« Reply #8 on: January 30, 2018, 12:55:19 pm »
Hey, I use the program Altami studio, myself I use it with Windows and to be honest I haven't tried it on ios... but I know it is a cross-platform app, let me know if it works there as well 8)
Offline tyrel
« Reply #9 on: January 30, 2018, 07:20:22 pm »
The OpenCV library is by far the most popular framework for image processing, and there is an android sdk.
Starting point : https://opencv.org/platforms/android/
A lot of standard image processing functions are implemented, and what you want to do should take only a few lines
A good starting point could be
https://docs.opencv.org/3.3.1/d3/db4/tutorial_py_watershed.html
for the principles at least, of course you won't use the python api on android
