Right now I'm attempting to source an adhesive bluetooth antenna with a 200-mm wire. Due to mechanical limitations this will be the best placement for this.
I'm seeing a fair amount of 100-mm or less. Does the antenna cable itself need to be less than the wavelength of the signal?
