Author Topic: Antenna wire length limit for Bluetooth  (Read 6049 times)
Offline Pack34Topic starter
« on: November 21, 2016, 10:14:00 pm »
Right now I'm attempting to source an adhesive bluetooth antenna with a 200-mm wire. Due to mechanical limitations this will be the best placement for this.
I'm seeing a fair amount of 100-mm or less. Does the antenna cable itself need to be less than the wavelength of the signal?
Re: Antenna wire length limit for Bluetooth
« Reply #1 on: November 21, 2016, 10:28:18 pm »
I'm attempting to find one of these with a length of 200-mm
http://www.digikey.com/product-detail/en/taoglas-limited/FXP70.07.0053A/931-1074-ND/2332701
I was able to find this Molex one, but it looks like it'll be just a hair too short. I think I really need 200-mm.
http://www.digikey.com/product-detail/en/0479501011/WM5032-ND/2709380
Can anyone help me out?
Offline Monkeh
« Reply #2 on: November 21, 2016, 10:38:34 pm »
What's wrong with this? http://www.digikey.com/product-detail/en/molex-llc/0479502001/WM5030-ND/2709378
Or this: http://www.digikey.com/product-detail/en/molex-llc/0479502011/WM5033-ND/2709381
Or something else from the 109 2.4GHz antennas with 200-300mm tails: Long URL here
No. In fact, many antenna cables in laptops are longer than 200mm.
However, the longer the antenna is, the more loss it is going to attenuate.
Surely if you attenuate loss, you gain?
The following users thanked this post: Pack34
« Reply #3 on: November 21, 2016, 10:47:26 pm »
I... completely missed those.
Thanks!
Online Zero999
  • 0999
« Reply #4 on: November 21, 2016, 10:50:04 pm »
He meant, the longer the cable, the more the signal will be attenuated.
Offline Monkeh
« Reply #5 on: November 21, 2016, 10:50:40 pm »
You know, I can figure that out.
