I've been experimenting with some of the very first Fairchild, "micrologic" series, integrated circuits. These are the same type of ICs used to build some versions of the Apollo Guidance Computer (AGC.) I was able to located a few uL923 parts, which are documented as JK Flip Flips, and get them working as a ripple counter. The AGC is said to have been built entirely using dual, triple NOR gates in flat packs, but I have been unable to locate similar parts on the surplus market. So, I settled for using the uL923 which, while in the same family as the ICs used in the AGC, are packaged in expoy-based, TO-99 configuration. If you're interested, I've written a short article with a demo video which you can see here:
https://sites.google.com/site/wayneholder/apollo-era-digital-logicThese early fairchild RTL ICs were used as the basis of quite a few projects in the old American hobbyist magazine "Popular Electronics". For example, Don Lancaster's "IC-67 Metal Detector" on page 41 of the the January, 1967 Issue (
http://www.americanradiohistory.com/Archive-Poptronics/60s/67/Pop-1967-01.pdf) was based on the uL914, which is a dual, two input NOR gate that's very similar to the parts used to build the AGC. Lancaster even managed to use these "digital" ICs as analog devices in the receiver portion of the metal detector.
Wayne
