Author Topic: Arduino function gen  (Read 7123 times)
Offline House91320Topic starter
« on: April 04, 2011, 04:50:11 am »
I am working on a arduino function gen and I am hitting a wall. The ardduino isn't fast enough to generate the desired hrz is anyone aware of a frequency multiplier.
Offline PeterG
Re: Arduino function gen
« Reply #1 on: April 04, 2011, 05:13:55 am »
An Arduino by itself wont be able to do it, however you can use an Arduino to control a Waveform Generator IC such as a MAX038 or a ICL8038.
Regards
Testing one two three...
Offline bilko
Offline scrat
« Reply #3 on: April 04, 2011, 02:20:45 pm »
It depends on the frequency range you need and the waveform (square, sine, ...).
In the case you need an accurate frequency into a limited and enough high range, you can use a PLL (e.g. 74HCT4096 / 9046) together with the PWM peripheral of the Arduino and a divider, in order to "multiply" the output frequency.
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
Offline buffalo960
« Reply #4 on: April 05, 2011, 09:52:00 pm »
You should mention that you are using a digital Pot to do it.
« Reply #5 on: April 05, 2011, 11:45:03 pm »
My mistake.
Alex
  • Guest
« Reply #6 on: April 06, 2011, 12:25:22 am »
Pfff...there is a plug-n-play board for anything these days.
As mentioned, with the power of the arduino the best thing you can do is to use an external DDS chip (even for low frequencies) so you can use the arduino to implement a user interface to the DDS chip.
