Author Topic: Both edge detector troubles  (Read 2179 times)
Offline VakitoTopic starter
« on: September 23, 2020, 12:14:57 pm »
Hi all, been trying to make a 12v edge detector that pulses when the input goes from high-low or low-high.
I have had no luck whatsoever though and the output is uselessly high all the time. Does anybody have any better circuits or even better point me in the direction of an off the shelf circuit I can hook straight up?
Thanks
Peter
Offline Kalvin
  • Embedded SW/HW.
Re: Both edge detector troubles
« Reply #1 on: September 23, 2020, 12:23:40 pm »
Are you using real CD4077? I mean, if you have substituted the 12V 18V-tolerant CD4077 with a modern "compatible" device, you have probably fried the IC as the modern devices are typically designed for maximum of 5V power supply.
Edit: Fixed the maximum VCC voltage.
« Last Edit: September 23, 2020, 12:28:27 pm by Kalvin »
« Reply #2 on: September 23, 2020, 12:34:33 pm »
I've used a Texas Instruments CD4077BE
Offline Kalvin
  • Embedded SW/HW.
« Reply #3 on: September 23, 2020, 12:50:38 pm »
TI CD4077BE is a 18V tolerant device, which is correct.
How do observe the output? Do you have an oscilloscope?
You would probably want to add a series resistor for the other CMOS input in order to protect the device from static discharges.
Offline eblc1388
« Reply #4 on: September 23, 2020, 12:56:18 pm »
I don't know where you've obtained the above circuit, but its output waveform is wrong!
A 4077B will produce the exact logic level output as you've found out, normally high with very narrow negative going pulses when the switch changes state.
If you want the output to be normally low with positive going pulses, then use the 4070B instead.
The following users thanked this post: Vakito
Offline Kalvin
  • Embedded SW/HW.
« Reply #5 on: September 23, 2020, 01:03:26 pm »
You are absolutely right. The TI datasheet https://www.ti.com/lit/ds/symlink/cd4077b.pdf contains also the datasheet for the CD4070BE, and it is very easy to mix the devices. Luckily the CD4077 contains three other gates, and one of the remaining gates can be used as an inverter.
The following users thanked this post: eblc1388, Vakito
« Reply #6 on: September 29, 2020, 01:02:52 pm »
Hi again
I have modified the circuit with the extra 10k resistor but have kept the BE chip in place instead of swapping it with a B since it will be used to trigger a 555 monostable, I have simply connected the output to terminal 2 of the 555 via a 10k pull-up resistor.
However it is still not completely working, it works as a rising edge detector but not a falling edge detector.
I have the monostable set to 6 seconds powering an LED for testing purposes
Here's what's happening:
Say I quickly turn on and then off the input for terminal 1 of the edge detector, the LED lights for 6 seconds, fair enough
If I turn on the input for the edge detector for 4 seconds and then turn it off, the LED will stay lit for 2 seconds after I do so, 6 seconds total
If I turn on the input for the edge detector for anywhere above 6 seconds, the LED will stay lit until I turn the input off after which it will immediately stop lighting.
Obviously what should happen is I turn the input on for any amount of time and the LED should light for 6 seconds and when I turn the input off, the LED should again light for 6 seconds.
Any advice is apppreciated
Thanks
Peter
Offline eblc1388
« Reply #7 on: October 01, 2020, 06:06:48 am »
Connect a voltmeter between 0V and pin#2 of 555 and tell us the voltage in your various switching trials.
The voltage should always stay near 12V, no matter what you do to the input switching.
Offline S. Petrukhin
  • Country: ru
« Reply #8 on: October 03, 2020, 09:20:21 pm »
 :popcorn:
And sorry for my English.
