Hi again
I have modified the circuit with the extra 10k resistor but have kept the BE chip in place instead of swapping it with a B since it will be used to trigger a 555 monostable, I have simply connected the output to terminal 2 of the 555 via a 10k pull-up resistor.
However it is still not completely working, it works as a rising edge detector but not a falling edge detector.
I have the monostable set to 6 seconds powering an LED for testing purposes
Here's what's happening:
Say I quickly turn on and then off the input for terminal 1 of the edge detector, the LED lights for 6 seconds, fair enough
If I turn on the input for the edge detector for 4 seconds and then turn it off, the LED will stay lit for 2 seconds after I do so, 6 seconds total
If I turn on the input for the edge detector for anywhere above 6 seconds, the LED will stay lit until I turn the input off after which it will immediately stop lighting.
Obviously what should happen is I turn the input on for any amount of time and the LED should light for 6 seconds and when I turn the input off, the LED should again light for 6 seconds.
Any advice is apppreciated
Thanks
Peter
