Author Topic: Brake light.  (Read 12374 times)
Offline Calvin_SkinnTopic starter
Brake light.
« on: July 25, 2015, 03:20:02 pm »
I am trying to build a led brake light for my motorcycle and I don't know how exactly to manage resistors.
LED specs:
1 watt red
2.4v
.35amps
It is a 10v circuit.
My plan is to use 8 of them, 4 pares (of two LEDs wired in parallel) wired in series. How do I manage my resistors?
Offline sdg
Re: Brake light.
« Reply #1 on: July 25, 2015, 03:44:51 pm »
One LED fails, the other in the pair instantly gets twice the current, goes poof and voilà!, no more brake light...
 -sdg
Offline georges80
Re: Brake light.
« Reply #2 on: July 25, 2015, 03:49:07 pm »
High power LEDs should have a current regulated LED driver (DC : DC converter) to feed them. The driver also needs to withstand all the nasty spikes/surges etc of an alternator based charging system + inductive loads (starter motor) etc.
Beyond that (even though most won't care...), for street use there is typically some DOT requirement for all external lights on vehicles.
cheers,
george.
Re: Brake light.
« Reply #3 on: July 25, 2015, 04:53:33 pm »
So say a buck converter? the rectifier isn't enough?
Sent from my SM-G900V using Tapatalk
Re: Brake light.
« Reply #4 on: July 25, 2015, 04:54:27 pm »
I was thinking one resistor for each led.
Offline bills
Re: Brake light.
« Reply #5 on: July 25, 2015, 05:12:47 pm »
look here! http://led.linear1.org/led.wiz
Never argue with idiots. They drag you down to their level and beat you with experience.
Offline ConKbot
Re: Brake light.
« Reply #6 on: July 26, 2015, 01:45:25 am »
4 red leds in series isn't the best, in an automotive system as the system voltage changes, since the current limiting resistor is relatively small in value, the brightness will change more.
I've done a led "upgrade" for a friend who got an eBay aftermarket light that was shitty.  3 in series with a bigger limiting resistor was much more consistent in terms of brightness vs Vin. Though that was just little 50mA piranha leds.
The best would be to put them in series and use a boost driver. Georges80's website (www.taskled.com) is a good place, off the top if my head, the hyperboost driver should suit you, if it's still in production. No affiliation, just a happy customer.
Re: Brake light.
« Reply #7 on: July 26, 2015, 04:01:38 am »
Thank you.
Re: Brake light.
« Reply #8 on: July 26, 2015, 04:19:24 am »
Re: Brake light.
« Reply #9 on: July 26, 2015, 05:06:18 am »
Now why does this happen. In series 8 x 2.4v = 19.2v
8x0.35amps=2.8amps
19.2v x 2.8amps = 53.76 watts !?
2.4v x .35amps = 0.84watts
0.84watts x 8 = 6.72watts ?
Why aren't they the same? Obviously 8 1watt LEDs aren't going to use 53watts.
Re: Brake light.
« Reply #10 on: July 26, 2015, 05:37:55 am »
8x0.35amps=2.8amps
In the first calculation you showed you multiply the current (0.35A) in the series by 8x. BUT, it is the same 0.35A that flows through the entire series. So you multiply the series voltage 19.2V by 0.35A and you get the expected 6.72 watts.
thanks. I mixed it up with resistance. Wooo
Re: Brake light.
« Reply #11 on: July 26, 2015, 05:40:40 am »
Any recommendations on resistors I will need some thing around 6.9 ohms and over 7 watts. I found a 6.98 ohm 10watt resistor on eBay but it is $15. Any better options?
Offline AndyC_772
Re: Brake light.
« Reply #12 on: July 26, 2015, 08:36:52 am »
This cannot be a good solution. Calculate the LED current when the battery voltage is 12.0V, then 13.2V, then 14.4V, and you'll see why.
You'll also want to include some over-voltage and/or reverse voltage protection. LEDs won't react at all well to the kind of noise found on a vehicle electrical system.
Offline Neilm
Re: Brake light.
« Reply #13 on: July 26, 2015, 11:23:23 am »
Not a good idea - just imagine what would happen if one of those LEDs failed - no brake light.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Zero999
  • 0999
Re: Brake light.
« Reply #14 on: July 26, 2015, 12:04:27 pm »
A constant current source would be a better idea than a resistor.
LEDs tend to fail short circuit, rather than open circuit, so one failing wouldn't stop all of them from working.
Offline LaserSteve
Re: Brake light.
« Reply #15 on: July 26, 2015, 01:35:50 pm »
You really need a redundant system on a safety of life application like this. One commercially made light and one home made one.  I have a small led light on my bike, and then a larger one. I carefully avoid using the  exact same devices in parallel on safety of life systems.
High power Leds prefer current sources over resistors, they often  have nasty changes in their current vs voltage vs output    curves with respect to temperature.  Good heatsinking is  critical for peak brightness.
Second of all, automotive applications can have spikes in excess of 600V during starting.  Electric or Hybrid vehicles also have dirty electrical systems.  Good designs have spike and reverse protection of some form.
And if I have 8 leds, they are going to be in 4 strings of two or two strings of four, if one string fails, I still have a light.
There will also be a few T1-3/4  red led packages or piranha  packages there as a backup.
I used to be a nationwide field service engineer, constantly on the road.  It was fairly obvious the commercial LED lights for trucks were broken into several strings. The better ones clearly had constant current drivers, and the better ones have multiple brightness levels or motion effects built in.  Really good bike taillights often blink two times on application of braking, in order to better attract attention.
Consider this, in the US, your insurance may not feel obligated to fully pay out in an accident if you used a home made lighting system that did not meet DOT specs.
Steve
« Last Edit: July 26, 2015, 01:44:47 pm by LaserSteve »
"I calculated the stored energy, and it is enough to play the Dance / DJ Extended edition of "Baby Shark" in all 100 headsets for the production floor team simultaneously over 100,000 Times."
Well, I had to explain it to my boss, somehow.  He's an Accountant,  not a PHB.
Re: Brake light.
« Reply #16 on: July 26, 2015, 02:31:04 pm »
I don't understand what you're saying goes if I have a driver this won't matter.
Steve
Offline fmaimon
  • Country: br
Re: Brake light.
« Reply #17 on: July 26, 2015, 02:44:23 pm »
7 watts are way too much for a led brake light. You will blind everyone behind you!
Re: Brake light.
« Reply #18 on: July 26, 2015, 02:46:52 pm »
I made to be the same as what a normal bulb is: 400 lumens.
Re: Brake light.
« Reply #19 on: July 26, 2015, 03:09:44 pm »
Re: Brake light.
« Reply #20 on: July 26, 2015, 03:12:58 pm »
Will the leds potentially over drive one another?
Re: Brake light.
« Reply #21 on: July 26, 2015, 03:16:12 pm »
Just so it's out there it's a 1976 Honda cb550.
Offline AndyC_772
Re: Brake light.
« Reply #22 on: July 26, 2015, 03:30:45 pm »
A series resistor isn't needed at all if you have a constant current driver. If, however, you have a constant voltage driver, then a very small value resistor like this will mean the current is strongly dependent on voltage, and that's no good if the voltage is as variable as it will be on a bike's electrical system.
In any case, an LED has series resistance of its own; the forward voltage isn't nearly as constant as some electrical models would have you believe. The ESR of the string of LEDs cannot be ignored.
Offline fmaimon
  • Country: br
Re: Brake light.
« Reply #23 on: July 26, 2015, 04:23:29 pm »
Test it out before fitting. The way LED distributes its light is very different from an incandescent bulb. It will appear way brighter.
Offline miguelvp
Re: Brake light.
« Reply #24 on: July 26, 2015, 04:59:17 pm »
Just to throw this here.
Normal light bulb brake lights fail and it's not the end of the world. You just have to put a replacement one or you might get a ticket. In the meantime, left hand braking signal (angled downwards) should be sufficient.
That is if people still know what the hand signals mean :)
