Right, tea break is over, time to get back to work.
So, today I used this:-
To make this:-
Which is needed to accommodate this:-
The above is a Vent-Axia heat recovery ventilator. With no windows and the door likely to be shut tight throughout the winter months, ventilation is required. Vent-Axia claim an efficiency of 87% heat recovery on this unit. This is a 24V model with two speeds. High speed kicks in when the built-in humidity sensor detects an excess of 60% humidity. De-humidification is a by-product of it's heat recovery process.
Here I am in the process of wiring up the electrical outlets. There are 11 double outlets around the perimeter of the workshop. You can never have too many outlets and I have never quite figured out the point of single outlets. They are all wired back to the board in a ring main configuration via a 16A, 30mA RCBO. Plenty of power.
The board is looking a lot better now. I have a light switch on the right and on the left is the SMPS for the ventilator.
The worktops are now even more of a mess, but this because I have had to sweep and clean the floor in preparation for the next stage.
Some of you may notice that the ventilator is mounted at a bit of an angle, this is to allow the condensate to run outside of the building for obvious reasons.
I shall return with progress of the next stage sooner rather than later. We have been taking advantage of the good weather lately and have lit multiple fires on which to cook meat
