Author Topic: CC-Load, Again  (Read 2712 times)
Offline Thor-ArneTopic starter
  • Country: no
  • tinker - tinker, little noob.....
CC-Load, Again
« on: February 14, 2013, 12:41:02 am »
I've made Dave's CC-Load to.  ::)
First "slam together" ending with it osculating the load... Between 80 kHz and 190 kHz.
I guess I should read a bit more before putting it together, as I had no caps in there at all.  :palm:
Oh, well... That was the night-time version :p
So I skimmed through the various implementations discussed all over the forum and I ended up with the attached schematic, based on Jay_Diddys suggestions. This has been tested with a couple relative low power psu's, 1.5A@5V and 2A@12V. more testing when I finally get that lab-psu finished  ;)
The whole ting is mounted on a CPU heatsink with a fan, and I use 12V supply for it.
So far, so good. Some more testing, and I might expand it with a uC and display.
EDIT: Fixed schematic.
« Last Edit: February 14, 2013, 01:38:34 pm by Thor-Arne »
Offline slashguitar
Re: CC-Load, Again
« Reply #1 on: February 14, 2013, 01:16:12 pm »
Why did you connect the inverting inputs of the op-amps together?
  • Country: no
Re: CC-Load, Again
« Reply #2 on: February 14, 2013, 01:41:43 pm »
Doh, I didn't.....  :palm:
I just made that scematic from a cribble I did on paper, guess I didn't pay enough attention to what I was doing.  :o
Thanks for pointing that out.
It's fixed now.
